Upload capped again?/ Something screwy
- Upload capped again?/ Something screwy
- « Previous
- 1
- 2
- Next »
Re: Upload capped again?/ Something screwy
06-04-2009 4:08 PM
I have merged together two threads that I believe cover the history of the original poster's upload speed problem.
David (spraxyt)
06-04-2009 7:38 PM
And why can you not work a 7 day week, some people eh (just kiddin, I appreciate your help). Thinking about it, it was around the middle of last week when these issues started I think. However...... since I have moved to connect directly into the XTE faceplate, I have not once dropped sync, and uptime is just under 1 day, but I have had a loss of the PPP connection once. I will monitor this, it may be my Cat5E cable that was slightly faulty, and maybe the higher frequencies of ADSL2+ are showing it up, also it may be the london issues as well. The Cat5E cable is not proper CAT5E, it was bought from Clarity as an Engineers install kit. http://www.clarity.it/xcart/product.php?productid=16139&cat=250&page=1. It is rather stiff, and it could be breaking down I suppose. Was stable on ADSL though. Will wait and see......
06-04-2009 8:12 PM
06-04-2009 9:43 PM
07-04-2009 11:39 AM
Cheers
Chris
10-04-2009 3:05 PM
Also the FEC/CRC error reporting appears to have gone back to normal.
Attached are the stats, do these now seem OK.
10-04-2009 5:11 PM
David
10-04-2009 5:38 PM
my line on adsl ran at 12db with a sync of 3500-3600 and stayed up for weeks with only 1 db variation over night.
if i ran sync at 4000+ overnight the variation in snr was 3db+ and would most likely drop connection but would always re sync with a 12db target i did the same on adsl2 and it lasted the night with the same 3db+ drop in snr but dropped the following day at about 4pm and re synced with a 15db target.
Its now running the same as this
Quote my line on adsl ran at 12db with a sync of 3500-3600 and stayed up for weeks with only 1 db variation over night.
but on a 15db target
11-04-2009 8:51 PM
Link Information
Uptime: 2 days, 3:02:50
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,060 / 7,267
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 24.0 / 44.0
SN Margin (Up/Down) [dB]: 7.5 / 2.0
11-04-2009 11:36 PM
David
12-04-2009 3:38 PM
Full Stats below.
Link Information
Uptime: 2 days, 21:49:53
SN Margin (Up/Down) [dB]: 7.0 / 3.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 85,731,008
CRC Errors (Up/Down): 0 / 999
HEC Errors (Up/Down): 0 / 891
Those odd upstream errors seem to have gone. Not yet resynced, so fingers crossed.....
13-04-2009 1:29 AM
David
- « Previous
- 1
- 2
- Next »
