Upload Uncapped Please
- Re: Upload Uncapped Please
- « Previous
- 1
- 2
- Next »
27-05-2012 8:55 PM
I've had a download speed of 0.9 Mbs all day today, looks like there is a fault after all.
27-05-2012 9:08 PM
27-05-2012 9:10 PM
27-05-2012 9:11 PM
Uptime: 0 days, 0:11:17
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 18,920
Bandwidth (Up/Down) [kbps/kbps]: 888 / 15,986
Data Transferred (Sent/Received) [MB/MB]: 1.67 / 7.39
Output Power (Up/Down) [dBm]: 10.5 / 20.0
Line Attenuation (Up/Down) [dB]: 15.0 / 26.0
SN Margin (Up/Down) [dB]: 17.5 / 6.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 379,654
CRC Errors (Up/Down): 32 / 1,642
HEC Errors (Up/Down): 9 / 33,652
28-05-2012 9:33 AM
What was the S/N up/down when you were having problems ?
I would need to check, but I would like to think that the upload sync would be higher than 888 with interleaving on given the margin of upload S/N you currently have.
28-05-2012 4:10 PM
28-05-2012 4:43 PM
28-05-2012 5:05 PM
Can't see anything awry with the profiles on BTs side or ours, though now there's an order on the line we can't raise any faults I'm afraid. I've checked the order though and there's a confirmed appointment for the 7th June so fibre won't be long.
I'm guessing a reboot of modem and router doesn't help with the slow speeds? Does a BT speed test show anything odd, profile wise?
28-05-2012 5:27 PM
like the line and equipment etc?
Resetting the router cures the fault temporarily and BT speedtester doesn't work it's never worked and yes I have java installed.
29-05-2012 10:21 AM
the engineer will just check that the modem he installed is in sync.
Jojo
- « Previous
- 1
- 2
- Next »
