Upload Speeds.
- Re: Upload Speeds.
Upload Speeds.
16-03-2017 3:36 PM
Hi - I'm currently getting upload speed of 0.39. Is this normal for basic adsl?
Re: Upload Speeds.
16-03-2017 3:40 PM
not normally
what connected speeds does your router show
Re: Upload Speeds.
16-03-2017 3:47 PM
If I do an upload speed test via iDrive I get 0.31 mb/s. should I be looking elsewhere?
Re: Upload Speeds.
16-03-2017 3:52 PM
provide the information requested then we can advise
Re: Upload Speeds.
20-03-2017 8:10 AM
Hi there @Russell666 I've tested your line and I can see your upstream sync is at 1048 kbps so I'd expect you to receive a better upload speed than 0.39 Mb. Are you using a wired or wireless connection?
