Uplink drops from 1200kbit to 448kbit
- Uplink drops from 1200kbit to 448kbit
23-04-2010 12:04 PM
Sudden change from 1200/1220/1240 uplinks to 448kbit, [edit -- 31.6 dB of SNR margin ]
has not revoved after a line reset from router web interface,
Please can some one help this?
Toby
sorry the cut & Paste ruins the formatting of some of the message
prior msg from PN telling me something I need help with the meaning / implications of the last bit:
Please, (interleaving , pros / cons )
Quote follows:
detail of response to a My Questions post..
BRAS Profile: adsl11000
Profile Info: WBC 160K - 24M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
11.6 6 0 0 10865 1215
Downstream Link Info
26.5 5.6 72 N/A 10282 16099
Downstream BIP Interface Data
Current Line Rate Line Rate Change TimeStamp Maximum Stable Rate Recalculated Profile TimeStamp Maximum Stable Rate Fault Threshold Rate Interleaving Flag
11000 15/04/2010 18:23:58 Y 01/04/2010 12:33:36 10208 8166 I
Kind regards,
link:csa removed
link:csa removed BOT - DSL Logged Faults 5:15pm, Monday 19th April 2010
Dear Mr XXXXXX,
Thanks for your reply
Our logs are showing a relatively stable connection, your IP profile should get updated to 14000 if your router managed to retain this connection for the next couple of days.
Although the interleaving flag is on, the MSAN is still not reflecting this, hence the errors on Downstream
If you are noticing any random connection drops please let us know so that we can place a regard order to put the line on a better Service Option that will encourage the DLM to trigger the interleaving.
Please do not hesitate to get back in touch online at http://contactus.plus.net or by phone on 0845 140 0200 if we can be of further assistance.
adie:red CSA names removed as per link:rules and also removed some personal information
Toby
Quote follows:
Upstream Link Info
Kind regards,
link:csa removed
Dear Mr XXXXXX,
Message 1 of 2
(692 Views)
1 REPLY 1
Re: Uplink drops from 1200kbit to 448kbit
23-04-2010 6:43 PM
Re-uncap my uplink please?
Toby
Toby
Message 2 of 2
(304 Views)
