Upgrading to upto 8mb
- Upgrading to upto 8mb
23-08-2007 9:54 AM
A couple of other things, if I do upgrade using the portal how long will it take before I see the upgrade?
Finally I have heard that upgrading will have Interleaving enabled on the line by default does this affect most people? as I now like to use Xbox live and don't want to be affected too badly by pings and response times etc..
Sorry one more thing does interleaving apply to LLU as well?
Re: Upgrading to upto 8mb
23-08-2007 9:58 AM
You won't be moved to BBYW if you request an upgrade.
If you ask me nicely, it'll happen tomorrow
I can also place the order without interleaving for you.
Interleaving does apply to LLU, but you are not on an LLU product.
23-08-2007 11:37 AM
Many thanks
23-08-2007 11:39 AM
23-08-2007 11:42 AM
23-08-2007 11:44 AM
You have another ticket on your account too
23-08-2007 11:47 AM
24-08-2007 9:16 AM
Do I have to do anything else ie.. get the profile changed at Plusnet now to get increased download speeds or will it now take up to 10 days before I notice an increase in download speeds?
24-08-2007 9:20 AM
I've just made a change to your profiling at our end. If you reboot your equipment, you should then notice an upturn in speeds.
24-08-2007 9:25 AM
