Upgrading router firmware problem
daniellewin89
Hi I currently have the Technicolor TG582n (FTTC), I've tried upgrading the firmware from 8.C.M.0 to 10.2.5.2.FO, however it doesn't seem to work, It goes through the installation process but stops and says it didn't work. I'm on windows 8.1 running the upgrade tool in windows 7 mode.
Is it possible to have it remotely pushed?
thanks
27 REPLIES 27
Re: Upgrading router firmware problem
Try this upgrade tool - http://www.binarybob.plus.com/thomson/Windows%207%20Upgrade%20Tool.zip
I think when I tried to upgrade mine, I had to set it to XP Compatibility using the original upgrade tool.
Fixes: 94
@daniellewin89
Yes we can push an upgrade through for you.
I've flagged that to the right person here and will do my best to give you a heads up when it's been done.
 Adam Walker
daniellewin89
Thanks, I think it is being done now.
Edit: Is wasn't, it just went down for a few minutes.
adie:quote
dags
Like daniellewin89, I would like to upgrade my router (Technicolor TG582n (FTTC)) software (from 8.C.M.0 to 10.2.5.2) and wonder whether I could also have it pushed? I'm also running a computer on Windows 8.1.
Fixes: 94
Hi dags,
That should be fine.
I've passed that on and it will most likely be picked up tomorrow.
 Adam Walker
dags
Many thanks.
dags
Dear Mr Walker
You kindly said two days ago that my request would probably be "picked up" the following day. However, the firmware version of my router remains the same. Do I need to do anything else to have my requested acted on?
Plusnet Alumni (retired) LinnPlusnet
Hi dags,
Really sorry for the delay. This should be sorted in the next 24 hours. Sorry for the wait!
Pettitto
Fixes: 5
We're doing this now, please do not switch off your router. You may notice a disconnection.
daniellewin89
Hi Chris,
I restarted my router because I thought it had just dropped its signal. Hope it hasn't caused a problem. If you need to start the process again, I'll know what happening now.
Quote from: Chris
daniellewin89
I'm thinking it was a bad idea to restart my router..
waynem41
I tried ( and failed) to update the firmware on my router a few weeks back , any chance someone at PN could push the update through for me please ?
Pettitto
Fixes: 5
@daniellewin89 - When would be a good time for us to put this through again? It's really important that we have no interruption with regards to the router through the firmware upgrade process.
@waynem41 - Would you be looking for the same firmware to be pushed?
daniellewin89
Hi chris, anytime from now until 3pm would be great!
dick:quote
