Upgraded to plusnet extra 60gb estimated speed 1MB but only getting 428kbs
- Upgraded to plusnet extra 60gb estimated speed 1MB...
- « Previous
- 1
- 2
- Next »
Re: Upgraded to plusnet extra 60gb estimated speed 1MB but only getting 428kbs
22-09-2010 2:52 PM
Easy way to check
Look at your router stats
If you have been changed your upstream will be 448kbps
Message 16 of 22
(343 Views)
22-09-2010 3:17 PM
HI Jim,
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 6000850 7845589 0 2051 8950 88:57:02
LAN 10M/100M 1510886 1501154 0 903 460 88:58:36
WLAN 11M/54M 6526266 4656554 0 8658 1956 88:58:28
ADSL Link Downstream Upstream
Connection Speed 576 kbps 288 kbps
Line Attenuation 60.0 db 31.0 db
Noise Margin 14.3 db 20.0 db
Nothing Changed yet I will wait patiently
Regards
Michael
Regards
Michael
Message 17 of 22
(343 Views)
22-09-2010 3:40 PM
your regrade request hadn't been picked up by the Provisioning Team so I actioned this manually for you, it will complete tomorrow. You'll then see the higher upstream connection speed and your line will start to train in. Please let us know how it goes!
Message 18 of 22
(343 Views)
23-09-2010 12:00 PM
Hi Ben,
My sytem has been upgraded to maxdsl heres the stats,
System Up Time 00:08:14
WAN PPPoA 7871 9844 0 2484 14131 00:07:33
LAN 10M/100M 2857 2549 0 986 634 00:08:07
WLAN 11M/54M 9330 7263 0 13783 2384 00:07:59
But download speed is still low,
Date Download Speed Upload Speed
Today 11:56 323 kbps (40.4kB/s) 355 kbps (44.4kB/s)
Could this be my router causing this problem or filter or is it an external wireing problem?
Many Thanks
Michael
Many Thanks
Michael
Message 19 of 22
(343 Views)
23-09-2010 12:37 PM
Michael,
You missed out the important bit of the stats , the ADSL Link stats...
The results of a speedtest at www.speedtester.bt.com and what does it say here https://portal.plus.net/my.html?action=data_transfer_speed for your current speed would also be useful in determining why your speed hasn't increased
Message 20 of 22
(343 Views)
23-09-2010 1:06 PM
HI michael41,
Your sync is low and this will cause issues. First thing I would do is plug directly in the test socket. Let me know when you've done that and I'll check it again for you.
Jojo
Jojo
Message 21 of 22
(343 Views)
23-09-2010 1:27 PM
Hi Jojo,
Just reebooted router and heres results,
Today 13:23 1242 kbps (155kB/s) 377 kbps (47.1kB/s)
Things are looking good
Thanks very much to everybody that has helped me
I must say the help on this forum is fantastic .
Many Thanks
Michael
Many Thanks
Michael
Message 22 of 22
(343 Views)
- « Previous
- 1
- 2
- Next »
