Upgraded to ADSL2 but poor speed
- Upgraded to ADSL2 but poor speed
31-03-2012 12:55 PM
I had been having problems in the last 2 weeks with slow speeds on adsl. My line profile had ben locked to 2500. This got raised to 7000 but the speeds were only 4megs. Prior to this I was getting on average 7 megs as I only live 200yds from exchange,
Plusnet upgraded me to adsl2 yesterday and speeds were worse but this morning i was getting 17.4megs! happy days, however it has now dropped to to 2 megs!.
Looking at my line stats there seems to be a lot of crc errors. can someone look at this and tell me if these stats are normal?
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 18:58:25
Downstream23,434 Kbps
Upstream446 Kbps
ADSL settingsVPI/VCI0/38
TypePPPoA
Modulation
TU-T G.992.5
Latency type
Interleaved
Noise margin (Down/Up)7.5 dB / 31.7 dB
Line attenuation (Down/Up)5.0 dB / 3.6 dB
Output power (Down/Up)
0.0 dBm / 12.8 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up4858 / 4294967295
CRC Errors (Down/Up7 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)2
Re: Upgraded to ADSL2 but poor speed
31-03-2012 1:05 PM
Can you run the BT Speedtest and see what this says https://portal.plus.net/my.html?action=data_transfer_speed
31-03-2012 1:16 PM
Hope this helps
The errors are in the correct order!
31-03-2012 1:21 PM
You would need to put in any old password I believe as that is ignored by the site.
What does the Plusnet link give
Regarding errors - either it is incorrect reporting or something is seriously wrong.
If you do the quiet line test - dial 17070 option 2 is there any noise
31-03-2012 1:33 PM
I cant get the test 3 to work. When I change the username it won't connect to the page
Other info from plusnet link:
High-speed Broadband
Estimated line speed:Not recorded (service activated before we introduced estimates).Current line speed: 21 Mb
Ive tried other router and just the same result
31-03-2012 1:40 PM
31-03-2012 1:43 PM
Thanks for your input,
I am plugged into master socket but have also tried another one , no difference.
I have run btspeedtest again and it now gives me this:...
1. Best Effort Test: -provides background information.
Download Speed
16.07 Mbps
0 Kbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 16.07 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 20.67 Mbps
Upload Speed
366 Kbps
0 Kbps 448 Kbps
Upload speed achieved during the test was - 366Kbps
Additional Information:
Upstream Rate IP profile on your line is - 448 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
31-03-2012 1:49 PM
I suspect that the very high number of errors was killing your connection
Did you resync or reboot the router before the latest test
By the way - the master socket isn't the test socket which you get to by unscrewing the lower half of the master socket
31-03-2012 1:53 PM
No I didn't do anything except try the quiet line test which came up....quiet!
Looking better now tho
I'll keep monitoring the speeds and the stats
Thanks again
01-04-2012 6:43 AM
I wouldn't trust the HEC & CRC error reporting from the HomeHub 2. In my experience it often misreports the figures, the counters start at a very large number after a reboot rather than zero. Here are my FEC errors just after a reboot.
FEC Errors (Down/Up) 0 / 4294967208
Sometimes a router reboot will correctly reset the counters to zero. If I remember correctly it only affects the Up stastistics, the down stastistics are reported correctly.
Your down errors look reasonable to me. I suggest you raise a ticket with Plusnet and then they will be able to look at the line stats in more detail.
Regards, David
