Upgraded to 21CN, still same d/l speeds
- Upgraded to 21CN, still same d/l speeds
- « Previous
- 1
- 2
- Next »
Re: Upgraded to 21CN, still same d/l speeds
27-03-2012 7:36 PM
28-03-2012 10:27 AM
03-04-2012 3:43 PM
My BT IP profile is STILL set to 7.15Mbps, despite having a ticket logged with Plusnet for over 2 weeks and support saying it should be ok now, and me still saying it isn't etc. etc.
Can Plusnet please get to the bottom of this.
03-04-2012 5:07 PM
I've just ran some checks and the bRAS and MSAN profiles are inconsistent. I've requested an SNR reset which should clear it. If not I'll raise a fault tomorrow and contact our suppliers to get it changed manually.
Jojo
03-04-2012 5:17 PM
Thank you very much.
04-04-2012 12:30 PM
04-04-2012 12:52 PM
I'll get working on this now for you.
Jojo
04-04-2012 1:44 PM
04-04-2012 1:54 PM
Thanks Jojo for getting this sorted out.
04-04-2012 3:24 PM
With attenuation of 37.8dB I'd say your line was over-performing at the moment to be honest. I think they've set it at 11Mbps manually. If you reboot then that should go up slightly.
Jojo
- « Previous
- 1
- 2
- Next »
