Upgrade threshold breached
- Upgrade threshold breached
Re: Upgrade threshold breached
16-02-2015 6:23 PM
Ping the IP address (if you know it) or if you want to do something a bit more comprehensive regarding DNS -
ping 192.168.1.254
ping 8.8.8.8
nslookup ntp.plus.net
nslookup ntp.plus.net 192.168.1.254
nslookup ntp.plus.net 4.2.2.3
nslookup ntp.plus.net 212.159.6.9
nslookup ntp.plus.net ntp.plus.net
ping ntp.plus.net
ipconfig /flushdns
tracert ntp.plus.net
The results of that lot will depend on what you have set your DNS set at as well as what's up or down but you get the picture I expect.
2) use www.downforeveryoneorjustme.com (if your DNS is working of course) to check a particular site.
17-02-2015 8:23 PM
. Best Effort Test: -provides background information.
Download Speed
4.51 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.51 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
17-02-2015 8:32 PM
18-02-2015 5:14 AM
18-02-2015 8:00 AM
18-02-2015 8:31 AM
Similarly the reason for ntp.plus.net is on the assumption that you are using Plusnet DNS as default. The list of checks was to see what was working when the TG582n proxy DNS server seemed to stop, but of course the principle can be used to check whatever you wish. HTH.
18-02-2015 9:33 AM
I haven't changed from the PN default DNS, as Tony said it would make running his checks more difficult. I just raised the DNS question as I stumbled across it somewhere. Mostly my connection issues correspond with a drop in speed, but occasionally I've noticed web pages taking forever to load, while a speed test shows nothing untoward.
21-02-2015 10:24 PM
Any thoughts?
22-02-2015 1:08 AM
22-02-2015 11:16 AM
As for searching this forum see http://community.plus.net/forum/index.php/topic,84049.0.html
A TBB BQM is a good indicator of congestion.
22-02-2015 6:14 PM
23-02-2015 10:57 AM
23-02-2015 1:22 PM
23-02-2015 1:43 PM
23-02-2015 2:22 PM
