Upgrade Blues
- Upgrade Blues
Upgrade Blues
19-05-2010 8:36 PM
Last Friday (in preparation for an upgrade from Value to Extra on 22nd) my line was moved from 20CN to 21CN, since when my throughput and IP Profile has nosedived 5000/5500 to 1500. Thinking my tired old 3Com router was partly responsible, this evening I connected my brand new Thomson TG585v7 supplied by your good selves (love the auto setup!). However the figures are much the same and mostly OK apart from an inordinately high number of FEC errors. The old router showed these as Interleaved Fec errors?
Is there a problem because I have not yet been regraded or is there an issue with BRAS/DLM/Interleaving?
Uptime: 0 days, 1:58:09
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,040
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 22.0 / 40.0
SN Margin (Up/Down) [dB]: 21.0 / 6.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 5,154
CRC Errors (Up/Down): 0 / 24
HEC Errors (Up/Down): 0 / 23
Regards
Mike
Re: Upgrade Blues
19-05-2010 9:03 PM
It doesn't look like the upgrade has completed yet (I can't chase that until tomorrow unfortunately). However, if your connection stays as it is now you should get a 6000+ IP profile within 3 days, and subsequently much better throughput speeds.
Re: Upgrade Blues
19-05-2010 9:08 PM
FEC errors?
Regards Mike
Re: Upgrade Blues
20-05-2010 5:57 PM
Mike
Re: Upgrade Blues
21-05-2010 10:27 AM
Down, Down, down
22-05-2010 1:53 PM
Broadband Product: Extra
Monthly Subscription: £11.49
After 0 months your subscription will change to £11.49
Estimated speed: 6 Mbps
This is an estimate of the line speed you'll get.
My throughput has descended from 4.8mb via 2mb, 1.5mb, 600kbs, 160kbs to 135kbs over the last 7 days!
I have raised a couple of tickets 33382803 & 33471729 which are supposed to be with a mystic entity called the regrade team.
In the meantime my IP profile seems to be disappearing up its own ...
My patience is now at an end and to be honest I am regretting moving from Value with its comfortable 4.8 MB throughput.
At the moment I am receiving a product which is not fit for the purpose it is intended and would be grateful if someone who knows what they are doing can sort it out.
Latest Router Stats (BT speedtest won't complete due to the low throughput)
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,112
SN Margin (Up/Down) [dB]: 21.0 / 9.5
FEC Errors (Up/Down): 0 / 266
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
Mike
Re: Upgrade Blues
23-05-2010 12:45 PM
BT Test 23rd May
Download speed achieved during the test was - 119 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :6048 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Is it worth disconnecting the TG585v7 Modem and reconnecting my old 3Com or should I continue to play the waiting game?
Rgds
Mike
Re: Upgrade Blues
24-05-2010 12:05 PM
Re: Upgrade Blues
24-05-2010 5:31 PM
A week or more ago I was enjoying a throughput of 4.8 surely if I am still on 20CN I should still be getting this - my throughput is now 130kbps and has been for some days. The whole purpose for the upgrade to Extra was to be able to take advantage of the 60GB with a view to using BBC Iplayer on Freesat more. Now I can't use it at all! (and I am now being charged for 60 GB I can't use!!)
Rgds
Mike
Re: Upgrade Blues
24-05-2010 5:41 PM
A BT speedtest will confirm it.
You had a few disconnects a few days ago which may be the cause, but the profile adjustment is a bit drastic.
Re: Upgrade Blues
24-05-2010 5:55 PM
Rgds
Mike
Re: Upgrade Blues
24-05-2010 6:13 PM
Quote DSL Type: G.992.1 annex A
You are still on an Up to 8Mbps ADSL connection, and as Mand stated it shouldn't take too long for the BT IP profile to increase, (bar a lower resync event in between}.
Hopefully the Plusnet profile will increase automatically without it needing a nudge to go up by PN Staff
Re: Upgrade Blues
24-05-2010 7:51 PM
Thanks for your input but Mand gave me the same message on the 19th - I lived in hope but here I am still on 131kbps with my router showing 5.9MB with 40 db att, I haven't done a BT test just yet as I suspect Mand may now have nudged the profile. I note that other users are suffering speed drops very recently and wonder whether there may be some sort of DLM problem?
Time will tell - I have only been waiting a mere 9 days! Another hour or so is not a problem - will post at about 21.00 with a BT Speedtest but I am not as confident as Mand that there will be an improvement.
Cheers
Mike
Re: Upgrade Blues
24-05-2010 9:08 PM
The test results show a 5985 connection speed with a 120 throughput, max of 250 and an IP profile of 135
My router is showing the same attenuation (40dB). Upload is 369.
Back to the DLM drawing board!
Rgds
Mike
Re: Upgrade Blues
25-05-2010 11:40 AM
