Updating to ADSL2+ when my exchange is enabled...
- Re: Updating to ADSL2+ when my exchange is enabled...
31-01-2010 11:36 PM
Hi all,
My account is Plusnet Unlimited, when my exchange is enabled ADSL2+ at the end of March will I automatically get updated to work with it ?
I've seen a few posts on the forum commenting about the attenuation of the line and thing I may have a problem there...?
The following is from my SAFECOM GART2-4115
Modem Status
Connection Status Connected
Us Rate (Kbps) 448
Ds Rate (Kbps) 8128
US Margin 28
DS Margin 2
Trained Modulation GDMT
LOS Errors 0
DS Line Attenuation 24
US Line Attenuation 11
Peak Cell Rate 1056 cells per sec
CRC Rx Fast 0
CRC Tx Fast 0
CRC Rx Interleaved 4647
CRC Tx Interleaved 146
Path Mode Interleaved
Nick - learning again
Modem Status
Us Rate (Kbps) 448
Ds Rate (Kbps) 8128
US Margin 28
DS Margin 2
LOS Errors 0
CRC Rx Fast 0
CRC Tx Fast 0
Message 1 of 4
(1,128 Views)
3 REPLIES 3
01-02-2010 9:12 AM
You can't have ADSL2+ on Unlimited.
If you switch to Pro or Premium you will get it. With your attenuation you could expect to get around 18000 Kbps.
Incidentally, have you looked at having interleaving turned off - your stats suggest that would be well worth a try.
Message 2 of 4
(406 Views)
01-02-2010 4:48 PM
How do you tell if interleave is turned on, on a DG834G?
Message 3 of 4
(406 Views)
01-02-2010 6:04 PM
Look at the telnet pages for the detailed stats. The easiest way to do that is using RouterStats
Message 4 of 4
(406 Views)
