Unlimited: Newsgroup access even slower!
- Re: Unlimited: Newsgroup access even slower!
16-10-2009 12:11 AM
We've been assured many times that our old product was not suitable for things like p2p and newsgroups. Eventually after almost 3 years we've caved in and upgraded to unlimited.
So why is access to the embarcadero newsgroups (codegear.com) so slow?
Message 1 of 8
(1,464 Views)
7 REPLIES 7
16-10-2009 3:20 AM
the network at the moment is still in plan b config http://usertools.plus.net/status/archive/1255451646.htm
all thoe if your speed problem was before the date of the service status it most likely isnt the cause
Message 2 of 8
(618 Views)
16-10-2009 4:11 PM
Any idea when we're coming off plan B I thought it was only in place for the MS updates and that was last Tuesday is there a problem somewhere?
Message 3 of 8
(618 Views)
16-10-2009 4:18 PM
On Wednesday, the unofficial word was that Plusnet would be returning to normal operation some time today.
Message 4 of 8
(618 Views)
16-10-2009 6:03 PM
belive they kepted the plan b in place due to the network being unblanced http://usertools.plus.net/status/archive/1255517583.htm
Message 5 of 8
(618 Views)
16-10-2009 7:28 PM
So the bottom line is that PN have told us newsgroup access would be better on unlimited and instead they've made it almost impossible to use.
I really can't believe this ISP anymore.
Plus, if this doesn't improve then we want to go back to our old package.
Message 6 of 8
(618 Views)
16-10-2009 8:34 PM
I have no problem with text newsgroups (either usenet or private groups) which are virtually instantaneous. And I'm on the old speed-limited BBYW1. So presumably you are talking about a binary Ng? Embarcadero newsgroups are not exactly mainstream.
So what speeds are you getting that cause it to be "almost impossible to use"?
http://www.plus.net/support/broadband/quality_broadband/speed.shtml
Message 7 of 8
(618 Views)
16-10-2009 11:34 PM
Looks like it'll be Monday now when more capacity is added http://usertools.plus.net/status/archive/1255723754.htm
Message 8 of 8
(618 Views)
