Unknown Gateway
paulgul
Unknown Gateway
Just checking to see which gateway I am on and it says I am connected to an 'unknown gateway'. Is there a problem somewhere or am I likely to be connected to the new pipe that was added last week.
Speed is ok even on usenet so no problems.
Paul
1 REPLY 1
Re: Unknown Gateway
The usertools gateway page has probably not been updated yet.
Post a tracert and if it contains thn-ag3 then you are on the new gateway.
