Unexpected Usage - Can anyone explain?
- Re: Unexpected Usage - Can anyone explain?
20-10-2015 10:09 AM
My wife and I, both pensioners, are modest users and for years have been on a 10GB per month contract. This has proved more than adequate although additional usage can be bought at £5.00 per 5GB. Our PC is hard wired into the router and we have a wireless connection for a Kindle.
Towards the end of September the usage suddenly increased to over 5GB PER DAY although our usage of the computers had not changed. The problem was via the wireless connection and, although we changed the incription, this did not solve the problem. We therefore shut down the wireless connection until we were able to establish and PAY EXTRA for unlimited usage. Shortly after this new unlimited contract was established our consumption suddenly returned to normal so we are now paying for more than we require.
To us this is a mystery although we hope someone out there can give us an explanation.
Message 1 of 6
(1,431 Views)
5 REPLIES 5
20-10-2015 10:27 AM
Do you run Skype? It used to be, and perhaps still is the case, that Skype will select some PC's to act as relays for other people's Skype traffic.
Otherwise run Malwarebytes anti-malware software on your PC to check for nasty software. You can get it here: https://www.malwarebytes.org/
Now Zen, but a +Net residue.
Message 2 of 6
(675 Views)
20-10-2015 10:56 AM
Hi Geejayjay,
Aside from your Kindle, do you have any other electronic devices in your property that may use a wireless internet connection?
Matty
Matty
Message 3 of 6
(675 Views)
20-10-2015 12:03 PM
If you check your usage for the month it also gives a breakdown of what was being accessed.
This might help narrow down at least what the traffic was for.
Might be that you had a weak Password on the router or was your router somewhere where the encryption key and SSID could have been read?
Message 4 of 6
(675 Views)
21-10-2015 12:59 AM
If a computer has been upgraded to Windows 10 then by default updates may be uploading to serve other Microsoft customers.
http://www.theregister.co.uk/2015/07/31/windows_10_torrent_updates/
Message 5 of 6
(675 Views)
21-10-2015 1:53 PM
Which you can turn off in Settings > Update and Security > Windows Update > Advanced Options > Choose how updates are delivered.
Message 6 of 6
(675 Views)
