Unbelievable slow broadband speed and lack of information from staff
Bedendo
It's been 5 days since I cannot have a minimum decent connection, making it impossible to access even the lightest websites (google.co.uk) properly. I have tried everything, from disconnecting all cables to factory reset.
I am getting (0.2 Mbps download speed by cable or wifi - when I was able to open the testing due to the slow connection). This which is far below the minimum guaranteed access line speed of 5.5Mbps promised.
I was in touch informing Plusnet that the problem is outstanding but had no answer on what is happening or how to solve it.
Really disappointing.
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 29
Re: Unbelievable slow broadband speed and lack of information from staff
Try & make contact with PN via CHAT link below.
CHAT needs your browser POP UP blocker to be turned off {for P Net URL's} for it to function.
Bedendo
Thanks, Gel.
I did this already first on Tuesday and every day since then.
Gel
Aspiring Champion
Fixes: 29
Fixes: 1,600
Hi there.
Sorry to hear you're having connection issues.
I can see you reported a fault to us on the 14th and we've added a reply today. While we aim to respond to a fault ticket as quickly as we can, we'd advise on a 3 working day timeframe for a fault to be picked up and investigated.
Following the changes we've made I can see your router is in sync at a stable line speed of 19mbps.
Can you advise if you're still having issues now?
If you are we'd recommend you first run a BTspeedtest at http://speedtest.btwholesale.com completing the further diagnostics at the end. This will store the result on the supplier system and aid us when reporting a fault to our suppliers.
