Unable to connect to Xbox live with Thomson 585v8
- Re: Unable to connect to Xbox live with Thomson 58...
18-01-2011 11:34 AM
Has anyone resolved this issue yet?
Can anyone assist me?
Message 1 of 5
(1,548 Views)
4 REPLIES 4
Re: Unable to connect to Xbox live with Thomson 585v8
18-01-2011 1:45 PM
HI RileyJ,
Have you upgraded the firmware on the router at all. If not, you can upgrade to 8.2.7.8 here.
Jojo
Jojo
Message 2 of 5
(480 Views)
18-01-2011 4:15 PM
Hi, Jojo
Yes done all that, the xbox links to router and then stops, won`t connect to internet, I`ve opened ports and typed in loads of different dns servers to no avail.
Fault is the dns server does not recognise xbox.
The router itself,w hen I check internet connection, it has a red cross next to both dns servers, although it connects to my computer ok, any ideas????
Message 3 of 5
(480 Views)
18-01-2011 4:54 PM
Hi RileyJ,
Have you enabled uPnP?
Jojo
Jojo
Message 4 of 5
(480 Views)
23-01-2011 11:20 PM
Now set the DNS to use DynDNS servers, guess what?
XBox Live now connecting
Router connectivity test passes with a full set of green ticks (failed on PlusNet default servers, Google and OpenDNS)
Now just had to pay for LIVE gold membership for my son as his current game requires gold for online multuiplayer
I DID also change the wireless settings to 'g' only just in case the 'kind-of-n' on the Thomson was causing problems with the XBox 'n' adaptor. I will try switching back after the boy has finished gaming.
Call me 'w23'
Message 5 of 5
(480 Views)
