Unable to browse
- Unable to browse
Unable to browse
31-08-2009 7:15 PM
I've had no connection since 11pm last night and I'm on the 21CN trial.
Or to be more specific, I've been unable to make use of the Internet since then, although my router is happily synching and authenticating.
CSC have done the usual checks, found no fault on the line (not really surprising) and bounced it back to me saying it's likely to be a fault at my end.
I've done all the usual, connected the router to the test socket without anything else attached, replaced the filters and no success.
If it was as simple as the connection dropping and being unable to resync I'd accept a fault at my end but all the diagnostics on the router say is is connecting successfully, it just can't access the default gateway or nameservers.
Any ideas?
If all else fails tomorrow I'll have to purchase a new router to try but I'd rather not.
Any ideas?
Message 1 of 6
(1,133 Views)
5 REPLIES 5
Re: Unable to browse
31-08-2009 7:44 PM
Can you ping your router?
What happens if you enter your routers address in your browser - something like 192.168.1.1 - where thost last two numbers may well be different?
Message 2 of 6
(360 Views)
31-08-2009 8:05 PM
It's not this issue again is it http://community.plus.net/forum/index.php/topic,76537.0.html
Can you check what public IP address your router is getting ?
Message 3 of 6
(360 Views)
01-09-2009 8:46 AM
Cruicible - I can connect to the router just fine, it responds as normal and shows a stable connection
MisterW - I'll check that when I'm back at home just in case.
Plusnet have advised me to borrow a router from a friend or relative - easier said than done of course - it's not like they're going to have spare ones lying around - not my rellies anyway.
Message 4 of 6
(360 Views)
01-09-2009 9:03 AM
If it's not possible for you to borrow a router, we can happily have one sent out on loan for you.
Message 5 of 6
(360 Views)
01-09-2009 5:40 PM
Bizarrely, I've come home from work today and everything is working perfectly again.
I guess we shall never know what the problem was! I blame BT.
Message 6 of 6
(360 Views)
