Unable to access Virgin Mobile website
rahewitt
I seem to be unable to access the virgin mobile website:
http://www.virginmobile.com/vm/payMonthlyPhones.do
Site never comes back Firefox and IE8 just report connecting... but never actually gets there!
It's been like this for 3 days now.  I've spoken to Virgin Mobile call centre and they say the website is OK.
Tracert reports the following:
Tracing route to www.virginmobile.com [92.238.96.40]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2    26 ms    35 ms    25 ms  lo0-central1.pcl-ag01.plus.net [195.166.128.232]
  3  117 ms    77 ms    26 ms  gi1-2-111.pcl-gw01.plus.net [84.92.6.0]
  4    25 ms    25 ms    25 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    25 ms    25 ms    24 ms  po4.pte-gw2.plus.net [212.159.1.188]
  6    24 ms    25 ms    25 ms  linx-gw1.router.ntli.net [195.66.224.22]
  7    26 ms    27 ms    26 ms  nrth-bb-1b-as0-0.network.virginmedia.net [62.253
.184.1]
  8    26 ms    27 ms    26 ms  nrth-bb-1b-ae6-0.network.virginmedia.net [213.10
5.159.33]
  9    30 ms    30 ms    40 ms  leed-bb-1a-as2-0.network.virginmedia.net [62.253
.185.102]
10    *        *        *    Request timed out.
11    33 ms    33 ms    33 ms  92.238.96.40
Trace complete.
Anyone any ideas?
21 REPLIES 21
Oldjim
Resting Legend
Fixes: 63
Re: Unable to access Virgin Mobile website
it looks as though some of the non text items are either blocked or not responding
rahewitt
Thanks oldjim, at least it's not just me.  Maybe I should hassle Virgin Mobile again?  Their FOREIGN call centre lady wasn't much help at all.  Just said it was working from there.
Fixes: 1,483
It's odd that every other country that you can get to from the landing page seems to be working, just not the uk one.
rahewitt
I'd not noticed that!
Does anyone have access to an alternative ISP, just to see whether it is PlusNet or Virgin Mobile that is at issue
Adie:quote
Fixes: 1,483
It works fine on my mobile, which is neither pn or virgin
rahewitt
Thanks Dvorak
avatastic
I've just tested from work (ac.uk, not Virgin) and PN and both work just fine.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
rahewitt
Hi avtastic, just to confirm, you've managed to access the link above via Plusnet? I still can't connect.
I wonder whether it is a 20cn/21cn issue?
john50
I've just accessed it from your link with no issues
avatastic
Quote from: rahewitt
Correct.
I'm not on 21CN here.
dratddestroyer
I cannot connect to http://www.virginmobile.com/vm/payMonthlyPhones.do
If I go to
http://www.virginmobile.com I get to chose my country. Probably something wrong at Virgin's end.
rahewitt
Thanks avatastic,
I'm using 21cn, I believe, and it still isn't working for me.  Site is available and visible from work.
Should I raise a ticket?
Strat
Fixes: 565
I left a tab open on the link for a couple of minutes and eventually closed it as a failure.
bobpullen
Fixes: 316
I can't connect from my home box either. I'm on 20CN.
Edit: Interestingly we had a few queries yesterday from Virgin customers unable to get to parts of the Plusnet network </plot thickens>
