URGENT help required...please!
- URGENT help required...please!
09-04-2009 1:11 PM
I have set up ann additional mailbox in my account.
I tested it by sending an email to my work (works fine)
I tested it by sending an email to new mailbox (works fine)
But when i try to 'REPLY' to the message sent from my new mailbox - Delivery has failed to these recipients or distribution lists:
*******@****.plus.net
The recipient's e-mail address is invalid. Microsoft Exchange will not try to redeliver this message for you. Please check the recipient's e-mail address and try resending this message, or provide the following diagnostic text to your system administrator.
QUICK FIX ANYONE - ITS IMPORTANT
[Moderator's note by Jim (Oldjim) email removed
Message 1 of 9
(1,617 Views)
8 REPLIES 8
Re: URGENT help required...please!
09-04-2009 1:20 PM
Try *******@*****.plus.com
Message 2 of 9
(762 Views)
09-04-2009 1:22 PM
HAHAHAHAHAHAH, what an absolute muppet
Never mind its long weeken time, woop woop!!
Thanks Dude
Thanks Dude
Message 3 of 9
(762 Views)
09-04-2009 3:54 PM
You may wish to edit your posts gentlemen and replace the specific identites in the e-mail addresses with generic ones, otherwise spam may be a problem!
Message 4 of 9
(762 Views)
09-04-2009 4:01 PM
jim:post As the problem is solved I have removed the email addresses mod:end
Message 5 of 9
(762 Views)
09-04-2009 8:13 PM
problem is back.
i set it up and works perfectly in Outlook.
But outlook express is failing. Think its a ticket issue this time though !!!
Message 6 of 9
(762 Views)
09-04-2009 11:33 PM
I wouldn't have any great faith in Outlook express...
Have you tried using Thunderbird, ideally as IMAP - the visual interface is quite similar.
Message 7 of 9
(762 Views)
10-04-2009 7:33 AM
Surely if the settings are all right it should work.
Will try thunderburd though
Message 8 of 9
(762 Views)
12-04-2009 12:25 AM
I have been using OE for years with no real issues. Most of the time problems have been due to servers not being found/available.
Message 9 of 9
(762 Views)
