Turning off interleaving
- Turning off interleaving
02-08-2011 5:11 PM
Hi, I have recently requested interleaving be turned off via the member centre... is there anywhere I can check the setting to make sure it has been completed and I'm now on fast path? Using a Thomson TG585 v7 router but cannot see a path mode setting on it :-
Any help appreciated.
Update:As in my last post it seems I still have interleaving on, contacted customer service via the member centre again who had told me it had been switched off. Apparently it was only set to automatic, they have now requested it off which is due to be completed Aug 5th, although they said they expected the line may be unstable but well see.
Message 1 of 5
(1,508 Views)
4 REPLIES 4
Re: Where to find interleaving/path mode setting info?
03-08-2011 12:05 AM
Sorry, I don't know if that particular router has easy access to the information you require though I think Routerstats does display it with this model.
Another simple option is to ping bbc,co,uk, if you get a ping much less than 20ms then you can pretty well conclude that you're on Fast Path (I have interleaving off and typically get a ping between 13 and 16ms to bbc,co.uk), when interleaved my typical ping to the same address was 22 to 26ms.
Call me 'w23'
Message 2 of 5
(475 Views)
03-08-2011 2:27 AM
Alternatively check the FEC error count. If it stays at zero you are on Fast Path. If it doesn't then it's Interleaved.
David
Message 3 of 5
(475 Views)
03-08-2011 3:19 AM
@walker23 the ping check is dependent on the line length, my own which is fairly long averages 30 when on fast path and 50ish when interleaved.
FTTP 500 regrade from Tues 28th November
Message 4 of 5
(475 Views)
03-08-2011 8:04 AM
Thanks for all replies, have downloaded routerstats and it is still showing as interleaved as suspected (I requested it off last Friday) :
Modemstate : Up
xDSL Type : ADSL
xDSL Standard : ITU-T G.992.1
xDSL Annex : Annex A
Channel Mode : Interleaved
Uptime (days hh:mm:ss) : 1 day, 14:12:47
Ping to bbc.co.uk is 32ms on average at moment too and showing FEC errors.
Modemstate : Up
xDSL Type : ADSL
Message 5 of 5
(475 Views)
