Tune-Up Utilities.
- Re: Tune-Up Utilities.
Tune-Up Utilities.
19-10-2013 2:51 PM
Also I have tried pinging the Tune-Up site but the requests time out.
This is the website link.
http://www.tune-up.com/
Can anyone else try it please?
19-10-2013 2:52 PM
C:\Users\Jim>tracert www.tune-up.com
Tracing route to a1129.b.akamai.net [23.62.99.178]
over a maximum of 30 hops:
1 10 ms 99 ms 99 ms 192.168.1.254
2 33 ms 32 ms 33 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 32 ms 33 ms 33 ms link-a-central10.pcl-gw01.plus.net [212.159.2.160]
4 33 ms 32 ms 32 ms xe-10-0-0.pcl-cr01.plus.net [212.159.0.192]
5 37 ms 32 ms 32 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 32 ms 32 ms 32 ms ae2.ptw-cr02.plus.net [195.166.129.5]
7 33 ms 48 ms 43 ms tge2-1-506.edge1.lon2.uk.as5580.net [195.66.237.111]
8 32 ms 32 ms 32 ms eth1-1.core1.lon2.uk.atrato.net [78.152.44.92]
9 38 ms 37 ms 37 ms eth4-6.core1.ams1.nl.atrato.net [78.152.44.78]
10 38 ms 42 ms 49 ms eth3-4.edge2.ams5.nl.atrato.net [78.152.44.40]
11 39 ms 38 ms 38 ms 78.152.38.234
12 41 ms 38 ms 38 ms a23-62-99-178.deploy.static.akamaitechnologies.com [23.62.99.178]
Trace complete.
19-10-2013 2:59 PM
[tt]traceroute to www.tune-up.com (23.62.53.99), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 3.023 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 20.874 ms
3 link-a-central10.ptn-gw01.plus.net (212.159.2.140) 21.006 ms
4 xe-8-2-0.ptw-cr01.plus.net (212.159.0.116) 40.398 ms
5 ae2.ptw-cr02.plus.net (195.166.129.5) 20.070 ms
6 *
7 a23-62-53-99.deploy.static.akamaitechnologies.com (23.62.53.99) 20.359 ms[/tt]
Installing a load of extra junk in an attempt to "tune up" your computer is a terrible idea.
19-10-2013 3:46 PM
I have even disabled the the firewall, but it made no difference.
I reckon it's a registry issue due to something I ran & blocked all access..
19-10-2013 4:53 PM
Slight update on this, just used a free proxy programme & it connected straight away. So does look like an IP issue.
19-10-2013 5:22 PM
Probably some malware blocking access to the site because the "Tune Up" stuff comes from AVG. Can you access www.avg.com ?
19-10-2013 5:22 PM
Quote from: Oldjim no problems at all and tracert gives
Trace complete.
My tracert to Tune-Up.com.
C:\WINDOWS\system32>tracert www.tune-up.com
Tracing route to www.tune-up.com [127.0.0.1]
1 <1 ms <1 ms <1 ms secure.tune-up.com [127.0.0.1]
Trace complete.
Different to yours.
Only one "hop".
19-10-2013 5:25 PM
A loopback address; a non-routable IP address that is defined as referring to the "local" computer.
19-10-2013 5:25 PM
Quote from: ejs Other PCs on your connection would appear to the website as coming from the same IP address, so it's not an IP issue.
Yes.
So it's not the device IP that is "sent". Is this correct?
19-10-2013 5:57 PM
Quote from: Oldjim I suggest looking at your hosts file
127.0.0.1
Thank you very much!
My hosts file got messed up like this.
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
127.0.0.1 secure.tune-up.com
127.0.0.1 www.order.tune-up.com
127.0.0.1 www.tune-up.com
127.0.0.1 www.tune-up.com/order
127.0.0.1 www.registertuneup.com
127.0.0.1 www.tuneup.de
I have reset it following this Microsoft link.
http://support.microsoft.com/kb/972034#LetMeFixItMyselfAlways
All is ok now.
Thanks again.
