Trying to resolve speed issue
- Trying to resolve speed issue
17-03-2011 7:14 PM
Im still having problems with this speed issue. I raise da ticket but still no response. I was just checking my ruoter page and came across this
Uptime: 0 days, 7:37:28
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 11.5
Line Attenuation (Up/Down) [dB]: 5.0 / 7.0
SN Margin (Up/Down) [dB]: 20.0 / 7.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 5
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
I also noticed someone with the same speed broadband and they had much higher line attenuation infact they had 20/16 is mine definitely set up correctly because my speed is rediculous. So much to the point now i just want to take the cancelling contract early charge and find another ISP. I cannot play black ops on the xbox even when i search for locale only games i still get red connection and severe lag to the point im just running from a spot and being lagged back to the same spot over and over again. When i go into bandwidth settings on black ops it says i have between 100 - 200 sometimes which is totally unplayable
Re: Trying to resolve speed issue
17-03-2011 7:33 PM
thanks
17-03-2011 7:44 PM
Second, you are syncing at the fastest speed possible for ADSL Max. You say you have a speed issue but don't actually say what your current speeds are?
Do you actually mean you have a latency issue which is nothing to do with speed.
Post the results of a bt speedtest
What is your plusnet profile set to? https://portal.plus.net/my.html?action=data_transfer_speed
As for your SNR... That looks perfectly normal. What happens is the exchange normally has a min SNR target level of 6db and as it tries to increase the speed of the connection the SNR figure goes down. When the SNR figure hits the target level, that is the speed BT set for the line.
All package changes happen on your next billing date. It cannot be brought forward... however knowing it will not improve your latency you may need to reconsider.
17-03-2011 8:00 PM
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-03-17 19:31:41
Current line speed:
6.5 Mb
However whenever i play games im either in the red or amber zones no matter what part of the day I have latency issues but i never had them before. My internet was very stable and was totally playable. Now i have lagg in every game and connection issues when no one else i play with has and its not just once an hour it happens at least 3-4 times per 10 minute game and this is through the thomson modem and through my router. Doing pingtest gives me 30-40 ms and no packet loss but the internet is only just useable posting on forums. Loading viedos on youtube my internet cant keep up with the playback and has to pause to view the full video.
17-03-2011 8:07 PM
17-03-2011 8:11 PM
Also you appear to have interleaving on (a sycnc rate of 7616 is the clue) which will be adding 16->20ms to your latency. You could ask Plusnet to get it turned off and see if it helps (it can take a few days).
Also other people have been reporting speed issues and problems accessing some websites recently which may also be affecting you.
See what gateway you are on then try rebooting the router to get a different gateway and see if your problem improves.
17-03-2011 8:18 PM
This is located in City Lifeline House
I have turned my modem off about 5 times the last few days and it hasnt really changed anything. The biggest improvement i had found was to turn off firewall but i had to turn that back on really
i have asked for interleaving to be removed but i didnt think you were allowed on extra and only on the pro package?
17-03-2011 10:03 PM
18-03-2011 3:00 PM
I've placed the order to remove it for you, that should complete on Monday.
Hope that helps,
21-03-2011 7:46 AM
Thank you for that however i just noticed that i got a new ticket raised saying interleaving off has been rejected and failed. Is this normal?
21-03-2011 8:19 AM
21-03-2011 11:28 AM
