Trouble with public IP & VPN
eporeilly
Hi
I am experiencing trouble connecting to my work VPN and IT believe it is a problem with my public IP being outside of a usable range?
If i tether my laptop to my phone over 4G I can connect no problem, but over wifi it fails
Is there an easy way to change my public IP? I have tried turning the router off for a while and it did not change.
Thanks!
8 REPLIES 8
bobpullen
Fixes: 316
Re: Trouble with public IP & VPN
You can request a static IP here which will put you in a different range, but there's a one-off charge of £5. Whether or not your corporate VPN allows connections from your current IP address should be entirely within the control of whoever looks after your work VPN/IT architecture.
eporeilly
Hi
Thanks for the reply, I don't want a static IP, I can connect from my wifi sometimes, but other times I cannot connect for hours, but during that time I can connect fine form other networks.
IT at work have said they can see the connection coming in whenever it's not connecting from my end.
I have seen other people with similar issues saying it's to do with certain public IPs, so i just wondered if there was an easy way to get it changed rather than unplugging my router for hours and hoping to get a new one?
aesmith
Fixes: 4
Your company should be able to tell whether they block VPN access from certain address ranges.  It wouldn't be normal for a remote access VPN.
More likely it's something within Plusnet.  When I was on PN broadband there were firewall options configurable on your account. I had to switch all that off before remote access VPN would work.
eporeilly
I did ask them and I'm pretty sure they said mine wasn't being blocked, I can get through sometimes but not others.
I've tried disabling the firewall on the router but no luck, tried clamping the UDP port to 500 but that didn't work.
I'll have a look at the account, I think it's something within plusnet as well.
eporeilly
Firewall is off in the account settings as well, nightmare!
bobpullen
Fixes: 316
@eporeilly wrote
:..so i just wondered if there was an easy way to get it changed rather than unplugging my router for hours and hoping to get a new one?
No easy way I'm afraid, and dynamic IP's are assigned geographically now so there's a change those you'll be allocated are all from similar pools/ranges.
eporeilly
ok, thanks for your help!
I paid the £5 in the end for the static IP, fixed things for a few days but now having the same issue as before Sad
bobpullen
Fixes: 316
@eporeilly I've applied a £5 credit to your account to cover the cost seeing as it hasn't helped. The IP you've been assigned is from a well-established range (same range as mine as it happens), so there definitely shouldn't be any routing issues, nor any inerrant port restrictions.
Might be worth establishing whether or not there's any local logging that can be extracted from your VPN client software. Maybe something your helpdesk/IT bods can help with?
I'd normally suggest trying to trace to the VPN endpoint at this stage, but seeing that your IT dept seem to be able to see your connection attempts, then this doesn't seem worthwhile.
