Transparency, please, with estimated FTTC speed
- Transparency, please, with estimated FTTC speed
Re: Transparency, please, with estimated FTTC speed
20-11-2012 8:55 AM
Quote from: Anotherone and Plusnet must kick them until it is resolved satisfactorily.
Yep, this is central to a solution. So, just how do you get Plusnet to get interested? There seems to rest the biggest challenge
20-11-2012 9:00 AM
Quote from: Anotherone IMHO another OR visit should not be needed until they have solved the routing issue about which cabinet you should be connected to.
'Should' or 'are'. I know which cabinet BTOR say we are connected to (1771m away) but how would I find out which cabinet we should be connected to?
Is there an accepted definition somewhere of what a provider is allowed to call 'superfast' broadband?
20-11-2012 9:20 AM
Quote from: pieplanter 'Should' or 'are'. I know which cabinet BTOR say we are connected to (1771m away) but how would I find out which cabinet we should be connected to?
There is a leaked BT spreadsheet floating around from December 2011 (so quite old now) which lists cabinets against postcodes. It won't tell you exactly which properties are connected to each cabinet, but should indicate whether multiple cabinets serve a given postcode (although of course if the records are wrong for your line and you're the only person on that cabinet, it won't be much help). For my street for example 97% are served by Cabinet X but the remainder are on Cabinet Y.
Have you checked on the BT Wholesale checker for neighbouring properties? The postcode-only checker won't be much use but using either the telephone number or house number + postcode checker will indicate what BT think that particular property should get.
20-11-2012 9:40 AM
20-11-2012 4:25 PM
Quote from: chrispurvey I appreciate that you are not overly happy with the quality of service...
...we are awaiting a further update from our suppliers(due today)
@chrispurvey
I take it, then, that you didn't get the update yesterday and not today either?
20-11-2012 4:34 PM
As per PM you may be on Cab P22, listing says a 10x uplift, so only 21M if you only had 2M on ADSL2+, but have a look around there may be a newer cab just coming online that is within this currently mythical 400m.
20-11-2012 4:42 PM
As for the lack of update, this is nothing more than I've had to put up with for the past 3 weeks. Having said that, I've just seen this on the blog...
“Its great to be named ‘Best broadband Supplier of the Year 2012’ by readers of Computer Shopper magazine and the award is a great reflection of the high quality products and services we provide here at Plusnet.”
Does anyone know where I can get some of this?
20-11-2012 6:02 PM
Faults update will depend on OR/BTw feedback, and whilst BTw might be saying this is a long line they may take longer to provide feedback to PN - takes longer to get out the other end of the longer wire
20-11-2012 6:28 PM
Well done you. We are connected to cabinet P22 which, the BTOR engineer told me, makes us 1771m long. There is a nearer green cabinet, marked 34, which is only 350m away but that doesn't have the flashy 'superfast broadband is here' poster on the doors.
What this obviously means is that Plusnet got it wrong when they gave us estimated speeds of 33Mb up and 5Mb down. That being the case, I now want Plusnet to come and take their gear away, and restore us back to where we were before they messed up. And, all at no cost to us.
Just three other points:
- our current 'superfast broadband' line speed is 10.1Mb as reported by Plusnet
- I'm not bothered if this is a BT/ W/OR mistake because my contract is with Plusnet
- to everyone out there, on the 'this is only an estimated speed' bandwagon, the information that we went by, which is clearly stated everywhere on Plusnet's website, is that estimated means +/- 1Mb and NOT +/- 20Mb
In this respect, we are simply lay people. We have to trust and rely on what we are told by the experts. It's now time for Plusnet to make atone and release us from this misery. TalkTalk here we come!
20-11-2012 6:37 PM
Quote from: Anotherone Whilst I have hammered Plusnet with some criticism lately...
Obviously, I don't know what line of business you're in, but in mine you simply don't let your customers down; good communication is God. An email or text takes what, 2 minutes of anyone's time? No excuse, I'm afraid
20-11-2012 7:28 PM
As for TT, you are joking, have you seen http://community.plus.net/forum/index.php/topic,108596.html
20-11-2012 8:10 PM
For Telephone Number 01209##### on Exchange REDRUTH
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 3Mbps; typically the line speed would range between 1.5Mbps and 5Mbps.
Our test also indicates that your line should be able to have an ADSL2+ broadband service that provides a fixed line speed up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 3Mbps; typically the line speed would range between 1.5Mbps and 4Mbps.
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 33.8Mbps and upstream line speed of 5.9Mbps.
What do you make of this?
As for TalkTalk. We've been there before. When it works you can't buy better
20-11-2012 8:27 PM
That said, the estimates for ADSL(2+) suggest your line is not behaving as it should. Can you hear/have heard any audible crackling or other noises when using the phone? Have you had any problems with incoming or outgoing calls?
As for TT, did you read all that thread, clearly it could cost dearly when they foul up
20-11-2012 8:36 PM
Quote from: pieplanter Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 33.8Mbps and upstream line speed of 5.9Mbps.
The wording of that paragraph leaves a lot to be desired but I've always assumed it means many customers attached to your cabinet receive those speeds. I assume these are those at more normal distances from the cabinet.
20-11-2012 8:58 PM
Quote from: Anotherone Well, what I make of that is another BTw/OR foul up and Plusnet gets the flack.
As customer we deal with Plusnet. If, in turn, Plusnet has an issue with one of their suppliers then surely it's up to Plusnet to put the procedures in place to deal with those issues promptly? In my case we're 3 weeks down the line and, as far as I can see, Plusnet haven't done anything!
Quote That said, the estimates for ADSL(2+) suggest your line is not behaving as it should. Can you hear/have heard any audible crackling or other noises when using the phone? Have you had any problems with incoming or outgoing calls?
The only thing I can detect is that the sound is slightly 'muffled' but that's because the telephone is a cheap and cheerful five quid Argos jobbie
Quote As for TT, did you read all that thread, clearly it could cost dearly when they foul up
TalkTalk is a tongue in cheek remark. What I'm leaning very rapidly is that you 'pays your money and takes your chance'. I have been saying for some now that we should pay a bit extra and go to a class provider that can deliver, whatever the problem.
