Transfer to 21C Network/REIN Problem [RESOLVED]
- Transfer to 21C Network/REIN Problem [RESOLVED]
Re: Transfer to 21C Network
11-06-2013 12:19 PM
Do you know if any of your neighbours do anything on a Friday evening and Saturday evening that they don't do the rest of the week?
11-06-2013 2:33 PM
You are currently connected to gateway ptw-ag04.
This is located in Telehouse West.
Phone exchange:
HOLYHEAD
Estimated line speed:
8Mb (This may vary between 6Mb and 10Mb) - Checked on 2013-04-23 02:54:03
Current line speed:
10.8 Mb
Download speedachieved during the test was - 10.16 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.05 Mbps
Upload speed achieved during the test was - 0.66Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
DSL Connection
Link Information
Uptime: 0 days, 2:48:37
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 12,523
Data Transferred (Sent/Received) [MB/MB]: 402.54 / 185.86
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 14.3 / 27.5
SN Margin (Up/Down) [dB]: 14.1 / 12.0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 22 / 134
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 16
Average error rates over a 24 hour period
24 hours starting 11 Jun 2013 11:37:53
Per second Per minute Per hour Per day
CRC Up 0 0 0 0
Down 0 0.02 0.91 21.8
FEC Up 0 0.17 10.00 240
Down 0.01 0.66 39.5 949
HEC Up 0 0 0 0
Down 0 0 0 0
ES Up 0 0 0 0
Down 0 0.01 0.45 10.9
11-06-2013 2:58 PM
You definitely can't hear any audible crackling or other noises on the line when using the phone?
11-06-2013 3:18 PM
11-06-2013 4:29 PM
11-06-2013 6:53 PM
You are currently connected to gateway pcl-ag04.
This is located in City Lifeline House.
Phone exchange:
HOLYHEAD
Current line speed:
10.8 Mb
Download speedachieved during the test was - 8.7 Mbps
IP Profile for your line is - 10.66 Mbps
Upload speed achieved during the test was - 0.45Mbps
DSL Connection
Link Information
Uptime: 0 days, 2:13:06
Bandwidth (Up/Down) [kbps/kbps]: 888 / 12,086
Data Transferred (Sent/Received) [GB/GB]: 1.41 / 7.21
Output Power (Up/Down) [dBm]: 12.3 / 0.0
SN Margin (Up/Down) [dB]: 13.4 / 11.4
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 550 / 1
FEC Errors (Up/Down): 0 / 4,253,322
CRC Errors (Up/Down): 2,956 / 29,400
HEC Errors (Up/Down): 1,090 / 23,399
CRC Up 0.33 19.6 1179 28285
Down 3.29 197 11845 284278
FEC Up 0 0 0 0
Down 444 26648 1598886 38373268
HEC Up 0 0 0 0
Down 0 0 0 0
ES Up 0 0 0 0
Down 0.06 3.32 199 4779
11-06-2013 7:12 PM
Were you on pcl-ag04 before this happened? If you don't know try and keep a running log from now on, just in case.
Is it possible a neighbour (or even yourself) had switched on something electrical at that time?
11-06-2013 7:28 PM
Spoken to both immediate neighbours and neither have switched anything on around that time.
Checked 17070 and no unusual noise/crackling
One thing I have established, it's not the filter or the cable, as I just swapped out the router only. So narrowing down to the TG582n with new firmware or an outside influence
11-06-2013 9:16 PM
There's a full release of 10.2.2.B now there, instead of the demo version, it shouldn't be any different but give it a try tomorrow just to be sure. If that still gives the same issues then try the 10.2.5.2. but read the thread about it first.
I'm sort of thinking it's unlikely to be firmware if you had the issue before with 8.4.4.J.
11-06-2013 9:33 PM
11-06-2013 9:55 PM
12-06-2013 7:13 PM
You are currently connected to gateway ptw-ag02.
Phone exchange:
HOLYHEAD
Current line speed:
10.8 Mb
Download speedachieved during the test was - 10.38 Mbps
IP Profile for your line is - 10.73 Mbps
Upload speed achieved during the test was - 0.69Mbps
DSL Connection
Link Information
Uptime: 0 days, 20:42:55
Bandwidth (Up/Down) [kbps/kbps]: 888 / 12.161
Data Transferred (Sent/Received) [GB/MB]: 1,99 / 691,06
Output Power (Up/Down) [dBm]: 12,1 / 0,0
Line Attenuation (Up/Down) [dB]: 14,3 / 27,5
SN Margin (Up/Down) [dB]: 14,2 / 10,8
Error Seconds (Local/Remote): 19 / 0
FEC Errors (Up/Down): 30 / 993.361
CRC Errors (Up/Down): 0 / 597
HEC Errors (Up/Down): 0 / 6.391
CRC Up 0 0 0 0
Down 0.02 1.33 80.1 1922
FEC Up 0 0.07 4.04 97.1
Down 34.2 2052 123124 2954978
HEC Up 0 0 0 0
Down 0 0 0 0
ES Up 0 0 0 0
Down 0 0.04 2.16 51.8
13-06-2013 12:41 AM
Here's the crazy idea......... I've only recently moved from BT to PN. While I was with BT they used to throttle the bandwidth between 18:00hrs and Midnight. At the moment the UK is using BST( British Summer Time) and as such midnight(GMT) is actually 23:00 hrs. So the time frame 17:00 - 23:00hrs fits BT's throttling time of 18:00 - Midnight.
Crazy I know but possible ?
13-06-2013 8:23 PM
13-06-2013 8:55 PM
Whatever is happening can be as mild as causing my download speed to drop to as violent as making my dsl disconnect almost every 15 minutes but only in that 6 hour period. I live in a terrace street, so have neighbours both sides, across the street and behind me....... so if it is a local thing it is going to be almost impossible to find without special equipment
