Transfer to 21C Network/REIN Problem [RESOLVED]
Re: Transfer to 21C Network/REIN Problem
Sorry for the delay with the update, let us know how you get on come the 17th.
Good news at last.
Thanks for your patience. I've spoken to the REIN team and they have confirmed that the case is now awaiting closure as the engineer has advised no more sources of REIN has been identified. As soon as the engineers report has been submitted the REIN case will be closed.
I've tested your circuit and can see that the connection is remaining stable and the line quality stats are great. I will keep hold of the fault for a further 7 days for confirmation that the REIN case is closed and will then pass this fault ticket back.
Thank you for the update. I have monitored the line for the last week and the interference does seem to have disappeared.
I have been seen FEC errors of on average 150 per min with the occasional peaks of 2000 per min, but nothing major.
I agree with keeping this ticket open for another week to confirm, but would like to ask for a line reset. At the moment my upload/download speeds seem to be locked at 888/14330 respectively and the SNRM seems to be hovering between 7.5 and 8.0
Thank you for your help in this matter, I'm just disappointed it has taken 3 months to get to this stage, especially considering 3 weeks after the first letter requesting access and the problem has been solved. Why was the letter not sent right from the beginning ? To be honest I do believe I'm deserved some compensation for the delay in resolving this issue, instead all I have had so far is an increase in my monthly payments.
Regards
Gerwyn
Fixes: 5
I've had a quick chat with Will who's been dealing with this issue for you. He is going to wait to ensure the issue is completely resolved. Once this is confirmed and the REIN Case is closed, he'll be in touch with you.
Thank you for the line rest, seeing improvements already Smiley Smiley
Phone exchange:
HOLYHEAD
Estimated line speed:
8Mb (This may vary between 6Mb and 10Mb) - Checked on 2013-08-04 13:34:35
Current line speed:
12.6 Mb
Download speedachieved during the test was - 11.96 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 15.77 Mbps
Upload speed achieved during the test was - 0.26Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
DSL Connection
Link Information
Uptime: 0 days, 0:16:58
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 17,877
Data Transferred (Sent/Received) [GB/MB]: 1.01 / 889.33
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 14.2 / 27.0
SN Margin (Up/Down) [dB]: 14.4 / 6.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 17 / 0
FEC Errors (Up/Down): 0 / 863
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 4
I have replied to my ticket and would like to thank all those involved to get to this stage. It has taken over 3 months but I am happy that the REIN has finally been stopped.
I have asked on my ticket if Plusnet can nudge my current line speed as I am now syncing at 17877 kbps  Smiley Smiley Smiley
Thank you
Hey gtowen.
That's excellent news, I've nudged your profile for you. Will is due to re-test your line at some point today. As soon as he's done I'm sure he'll be back in touch.
Thank you Deano Smiley Smiley
Well all I can say is  Cheesy  Cheesy  Cheesy  Cheesy  Cheesy
Just a few days into the line training, and ...........
Phone exchange:
HOLYHEAD
Current line speed:
17.8 Mb
Download speedachieved during the test was - 16.83 Mbps
IP Profile for your line is - 17 Mbps
Upload speed achieved during the test was - 0.71Mbps
DSL Connection
Link Information
Uptime: 0 days, 4:27:13
Bandwidth (Up/Down) [kbps/kbps]: 888 / 19,265
Data Transferred (Sent/Received) [GB/GB]: 15.32 / 41.14
SN Margin (Up/Down) [dB]: 14.1 / 3.8
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 598 / 0
FEC Errors (Up/Down): 0 / 293,817
CRC Errors (Up/Down): 0 / 105
HEC Errors (Up/Down): 0 / 1,762
the speeds are great, althought the upload still seems to be capped, but an snrm of 3.8 and the line is still stable :).......... I am well pleased that I persisted with this  Cheesy  Cheesy  Cheesy
That's really good to see!
I'm glad the connection is stable now, Here's the graph:
Let us know if you have any further issues.
thanks Deano, for the moment the line is stable and speeds are gr8.
Not a major issue but the upload seems to be capped at 888.......... I know I have had uploads above 1.0Mb before so if this could be uncapped I'd be grateful Smiley
Fixes: 7
An upload of 888 is usually a sign of the line being on interleaved, not necessarily it being capped.
That's RPM to you!!
Ahhh thanks RPMozley, I knew interleaving was on but nobody mentioned the upload been held at 888.
I'm not a gamer so was not really bothered about interleaving been on.......... as long as the 888 max upload has no affect on skype, I'll leave it as is Smiley
Fixes: 75
If the connection remains stable (fingers crossed) it's possible that the DLM will remove upstream interleaving allowing upstream sync speed to increase to its natural maximum. It might take a while before that happens though.
David
Fixes: 6
@'gtowen' - now that you have come this far to improve your connection, you might as well try for maximum upload speed by raising a ticket to remove interleaving here - Help Assistant - Interleaving
If it doesn't work out any better, then you can use the same link to set interleaving back on again, or if problems are detected DLM might do it for you.
Wink
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.4.4-p3 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
@spraxyt Thanks for the info
@purleigh  Thanks for the link, atm the line is only 3 days into the 10 day training period, so I'll see what it's like at the end before making a decision Smiley
Phone exchange:
HOLYHEAD
Current line speed:
17.8 Mb
Download speedachieved during the test was - 16.14 Mbps
Upload speed achieved during the test was - 0.68Mbps
DSL Connection
Link Information
Uptime: 5 days, 4:11:05
Data Transferred (Sent/Received) [GB/GB]: 46.13 / 104.14
SN Margin (Up/Down) [dB]: 14.0 / 2.9
Error Seconds (Local/Remote): 2,713 / 0
FEC Errors (Up/Down): 305 / 4,235,475
CRC Errors (Up/Down): 2 / 3,782
HEC Errors (Up/Down): 2 / 60,862
Well, looks like everything has been sorted, thanks to all who helped in this matter. Smiley
