Training, use plusnet router?
dfects
Hiya,
Our line recently went active and rather than using the plusnet supplied router/modem I'm using a new Draytek Vigor 120 modem and my cable router. I'm just wondering if for the training period I should be using the plusnet modem or does it really not matter?
The draytek is reporting we're on G.DMT and syncing around 6/0.4 megabit up/down with an SNR around 6/7 and att around 42. Should this be switching to G.992.3 or G.992.5 at some point? Its been on all night and stable.
Thanks,
Ste
17 REPLIES 17
Oldjim
Resting Legend
Fixes: 63
Re: Training, use plusnet router?
It makes no difference which router you use
Regarding changing from G.DMT the first question is whether your exchange is 21CN enabled - check here http://usertools.plus.net/exchanges/
If it is then I should try setting the modem to auto rather than specifying it
dfects
Thanks for the reply 🙂 Thats good news
The modem is set to mixed modulation rather than specifying one. I assume this means its set by the line?
Code: WNOAK
County: Shropshire
Enabled: 03 Mar 2004
Market: 3
Mkt2014: B
Colour: Green 20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
Colour: Green BT have advised that this exchange is enabled for WBC on 21CN
Colour: Unknown You can view recent Service Outages for this exchange here
Colour: Unknown BT have published Max DSL upgrade information for this exchange
The following services are available in your location:
BT Wholesale ADSL
BT Wholesale ADSL Max
BT Wholesale WBC (21CN)
TalkTalk (CPW) LLU
Sky Broadband / Easynet LLU
Virgin Media (Cable)
Oldjim
Resting Legend
Fixes: 63
You should be on ADSL2+ or G992.5 so I wonder if the modem is reporting correctly
dfects
Not sure. I have the plusnet router, but didn't really want to switch anything off during the trianing process
Oldjim
Resting Legend
Fixes: 63
I think that you are in fact you may be on 20CN
As a check can you run the BT speedtest further diagnostics http://speedtest.btwholesale.com/
You should see something like this
dfects
I'm not really too sure what the difference between 20CN and 21CN is? Would I see faster speeds on 21CN? Is it possible to be put on 21CN if i'm not?
Oldjim
Resting Legend
Fixes: 63
You are definitely on 21CN but you may have been provisioned on ADSL1 G,DMT
Going to ADSL2 should give you higher speeds
I suggest leaving things alone until Monday when the staff on here should be able to check
dfects
Fantastic thanks for your help Smiley
orbrey
Jim's got it spot on, I've just placed an order to move you onto ADSL2+ with uncapped upstream which should complete tomorrow. Not sure what the speed increase will be like but hopefully you'll see some Smiley
dfects
Wow thanks Matt! Appreciate the quick customer service.
Will report back if I see any change in the next couple of days  Cool
dfects
Just to check, will line training begin again after our line is provisioned on ADSL2+? Or will it just continue Smiley
Pettitto
Fixes: 5
The line training will start as soon as you are moved on to ADSL2+.
dfects
Thank you for the reply Smiley Will leave my Draytek vigor 120 connected and restart it every morning as I have been.
Just to check in terms of training, is syncing the only thing that matters? As I'm currently using a separate modem and using my cable router to connect via PPPOE I'm wondering if rebooting the router but leaving the modem synced would make it think it was a disconnect and the line was unstable?
Pettitto
Fixes: 5
It *shouldn't* be a problem, however DLM may need the PPP session drops as a little unusual and may decide to band your line - it;s best to leave things connected for the initial training period as you can or if you're going to drop the connection, do this once or twice as this shouldn't have a detrimental effect on your connection.
The training period will recalculate your Fault Threshold Rate and Maximum Stable Rate so it's important we keep a stable connection throughput the training period.
