Traffic shaping during off peak hours?
- Traffic shaping during off peak hours?
- « Previous
- Next »
Re: Traffic shaping during off peak hours?
15-11-2010 11:47 AM
15-11-2010 12:18 PM
15-11-2010 1:49 PM
15-11-2010 6:07 PM
Quote Download speedachieved during the test was - 439 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Jojo, can you check the number associated with my account is correct and whether it being wrong would change anything?
It should end in 7958, the phone number at my old property ended in 7758 and I don't think the record was fully updated during the move, I've asked about 3-4 times for it to be changed.
Ta
16-11-2010 9:58 AM
can you PM me your full correct phone number please.
Thanks,
Jojo
16-11-2010 10:15 AM
16-11-2010 8:37 PM
17-11-2010 9:31 AM
Annoying. I'm going to reset the SNR which will hopefully kick it into action.
Jojo
17-11-2010 11:48 AM
17-11-2010 1:48 PM
It doesn't look like the SNR reset has had any effect so I have raised it to our suppliers and will keep an eye out for updates.
Jojo
18-11-2010 11:43 AM
18-11-2010 12:50 PM
I've just ran a line test and it's all showing as 7150 now, so all good Should be the same at your end now.
Jojo
- « Previous
- Next »
