Traffic shaping during off peak hours?
- Traffic shaping during off peak hours?
03-09-2010 11:22 AM
Is it possible the shaping hasn't been switched off at midnight? I've see this before and it resolves itself after a day or two.
Does anyone else get this?
Re: Traffic shaping during off peak hours?
03-09-2010 12:26 PM
03-09-2010 12:45 PM
I would suggest running a bt speedtest during those times, but your package off peak times are definitely between midnight-4pm
Jojo
03-09-2010 1:08 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
88 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 88 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :7072 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
03-09-2010 1:12 PM
I wouldn't disagree with you at this point but in order to start investigating something like this we would need to start gathering some evidence and take it form there.
Jojo
03-09-2010 1:15 PM
03-09-2010 1:30 PM
Just checked your connection logs and up until yesterday there were lots of short connections. This will be the cause of your IP profile dropping. It seems to have been quite steady since yesterday morning and if it continues to remain solid you will see it lift. Can I ask have you made any changes to your set up or if you are using any extension sockets/cables?
Jojo
03-09-2010 1:37 PM
Mrs SiMania did mention there was noise (probably the mother-in-law :D) on the phone that is connected to the master phone socket that she sorted by reseating the connection, that may have been it?
03-09-2010 2:43 PM
Tut about the quip! Anyway...
It may have been the noise, but I've just ran a line check and your current sync rate is 7072 so as long as it stays like that it should pick the IP profile up to 6000.
Jojo
03-09-2010 2:55 PM
03-09-2010 3:04 PM
We always quote 72 hours, but larger increases are normally a lot quicker.
Jojo
04-09-2010 10:36 PM
05-09-2010 12:20 AM
I should really get a life but I can't help checking in on you guys. Anyway, sometimes the router wil show an uptime of a certain amount but this can mean the time the router has been constantly on rather than a drop in connection. Here are the stats from your connection over the last 72 hours:
16:07 04/Sep/2010 N/A 8:3:51 (on going)
04:15 04/Sep/2010 16:07 04/Sep/2010 11:51:48
00:44 03/Sep/2010 04:15 04/Sep/2010 One Day, 3:30:28
17:48 02/Sep/2010 00:44 03/Sep/2010 6:56:0
06:27 02/Sep/2010 17:48 02/Sep/2010 11:20:58
06:24 02/Sep/2010 06:27 02/Sep/2010 0:2:53
06:23 02/Sep/2010 06:24 02/Sep/2010 0:0:43
06:17 02/Sep/2010 06:23 02/Sep/2010 0:6:15
06:16 02/Sep/2010 06:17 02/Sep/2010 0:1:2
06:06 02/Sep/2010 06:16 02/Sep/2010 0:10:21
It's defiitely improved but if it keeps dropping like this then I would sugest connecting the router in to the test socket to rule out any internal wiring issues because someting has started to interfere with the connection.
Jojo
05-09-2010 12:41 AM
Last dropped connection one was a planned one so it looks pretty stable since whatever caused it to go crazy on the 2nd Sep. If it is a dodgy phone then I might try to replace it with something else for a few days.
Thanks for checking in, I'm on here on a Saturday night trying to fix my connection so I have no life either!
05-09-2010 1:16 AM
I do have a life really...honest! Im just staying up to watch the rerun of X Factor as I missed it earlier.
I do hope it stays up in that case. The line check I did before showed a sync rate of 7456 so if it stays like that we should see a profile of 6500.
Jojo
