Traffic Management on Value Fibre
- Traffic Management on Value Fibre
15-05-2011 8:18 PM
Re: Traffic Management on Value Fibre
16-05-2011 1:27 PM
16-05-2011 1:30 PM
Results from speed tests would not be affected by traffic management so I'm not sure why you'd get those results. I'd suggest running the fault checker for some help with it.
Jojo
16-05-2011 1:48 PM
jim:quote
16-05-2011 1:56 PM
jim:quote
16-05-2011 2:00 PM
16-05-2011 4:49 PM
The fault checker is a diagnostic tool that is connected to the BT systems so it may have picked up a profile mismatch and rectified it.
Jojo
16-05-2011 9:22 PM
Edit: I have now completed the fault checker anyway - Question #42651915
17-05-2011 10:27 AM
17-05-2011 2:40 PM
Quote from: KevinG According to http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml browsing is restricted to 20Mb between 6pm and 10pm. So why am I being restricted to 10Mb?
Bah! I've just checked those pages with the information from the master traffic management rules sheet and there's a mismatch
From what I can tell the sytstem's actually doing this ('Browsing'):
18:00-20:00 = 20Mbps
20:00-22:00 = 10Mbps
22:00-23:00 = 20Mbps
With everything else in that row marked as 'Line speed'.
I've raised a problem to have it looked into (ref: 67044), however at present I'm unable to confirm which of the two sets of rules is the one the business signed off when the products were created
Sorry for the confusion!
just for the record, I'm pretty sure the BT Speedtest is exempt from the rate limiting to help from a diagnostic perspective.
17-05-2011 2:45 PM
17-05-2011 2:55 PM
There's no 10Mbps rate limit on Extra Fibre though.
17-05-2011 2:58 PM
17-05-2011 3:01 PM
17-05-2011 3:54 PM
