Time frame for upgrade?
- Re: Time frame for upgrade?
22-10-2018 6:51 PM
22-10-2018 7:08 PM
Assuming you are upgrading from ADSL to fibre you'll need a router that works with fibre, some routers work with both so it will all depend on what your current router is capable of. Routers are usually sent by first class post timed to reach you by your connection date.
The usual advise from PN is that any new service can 'go live' at any time up to midnight on the day they've specified.
A PN staff member will be able to look up the specifics of your account.
22-10-2018 7:09 PM
22-10-2018 7:22 PM
23-10-2018 9:25 AM
Hi @Wc21 Mind sending me a PM with your account username please? I'll be able to check the broadband and router orders to see where we're up to. it would be best if you can drop a quick reply to this post once you've sent it please. - Adam
23-10-2018 9:32 AM
I live in a shared house so the account is with the landlady, is there any other way to check?
23-10-2018 2:15 PM
Hi @Wc21 ,
We can certainly find the account via the telephone number the broadband is provided down, although unless we have authorisation on the account to deal with yourself we aren't able to divulge any account specific information.
We can definitely get a ticket over to the account holder with further information, once we've located the account., if that would be of use?
