Ticket problems
- Ticket problems
Ticket problems
29-09-2007 12:06 PM
Raised a ticket this morning requesting PN delete the spam on the f/way account (as unable to do so in webmail)
- error message
However I can't now see the ticket - it gives the number [ 22973670 ] and the date, but doesn't show any actual content.
Would appreciate the ticket (and the spam-deletion issue) being fixed, have only raised this here as assume the ticket system itself has problems.
Regards,
Penny.
- error message
Quote ERROR:
ERROR: Connection dropped by IMAP server.
Query: COPY 1:1635 "INBOX.Trash"
Regards,
Penny.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Message 1 of 7
(1,807 Views)
6 REPLIES 6
Re: Ticket problems
29-09-2007 1:59 PM
Hi Penny,
We'll get a problem raised about the ticket issue.
In the meantime I've deleted the mail in the 'Spam' folder.
Whilst on the subject, here's a quick tip for people as you can actually do this yourself using TELNET...
Firstly open a command prompt in windows (Start > Run, type 'cmd' and click OK)
Telnet to our IMAP server by typing:
You will be presented with a welcome message. You should then authenticate yourself using:
Note the space after the dot and the space between the username and password.
From here you can delete the Spam folder and its contents:
After pressing Enter you should get a confirmation message saying that the folder's been deleted.
You then need to recreate the spam folder:
Again there should be confirmation that this is complete.
And that's it! Should save you having to raise a ticket next time round
telnet imap.plus.net 143
. LOGIN <username> <password>
. DELETE INBOX.Spam
. CREATE INBOX.Spam
Message 2 of 7
(619 Views)
Re: Ticket problems
29-09-2007 2:34 PM
Quote from: Bob We'll get a problem raised about the ticket issue.
thanks Bob
Quote from: Bob In the meantime I've deleted the mail in the 'Spam' folder.
also thanks
Quote from: Bob Whilst on the subject, here's a quick tip for people as you can actually do this yourself using TELNET...
... And that's it! Should save you having to raise a ticket next time round
Very useful info, and appreciated you took the time to spell out the steps. Could you just clarify if <username> actually needs the chevrons, eg <bloggs> (?)
With regard to the actual spam deletion within webmail, though, why didn't this work? Always has, previously. Is there a certain volume of messages beyond which SquirrelMail can't clear down the spam?
Regards,
Penny.
Message 3 of 7
(619 Views)
Re: Ticket problems
29-09-2007 2:36 PM
Quote from: Penny Very useful info, and appreciated you took the time to spell out the steps. Could you just clarify if <username> actually needs the chevrons, eg <bloggs> (?)
No, it doesn't need the chevrons.
Quote With regard to the actual spam deletion within webmail, though, why didn't this work? Always has, previously. Is there a certain volume of messages beyond which SquirrelMail can't clear down the spam?
Yes, once the number of messages exceeds a certain amount Squirrelmail struggles. This leaves you in a position where you're unable to access the Spam folder to delete your messages.
Message 4 of 7
(619 Views)
Re: Ticket problems
29-09-2007 2:37 PM
Hi Penny,
Bob was only using them to help identify what was to go there, so you don't actually type them when you telnet in.
Message 5 of 7
(619 Views)
Re: Ticket problems
29-09-2007 3:09 PM
Quote from: Bob Yes, once the number of messages exceeds a certain amount Squirrelmail struggles. This leaves you in a position where you're unable to access the Spam folder to delete your messages.
Okay fine, if it's volume-related. I could see the messages, order them and toggle them, just couldn't get SM to clear them down. Thanks for clarifying
Regards,
Penny.
Message 6 of 7
(619 Views)
Re: Ticket problems
29-09-2007 3:15 PM
Quote from: MikeWhitehead Bob was only using them to help identify what was to go there, so you don't actually type them when you telnet in.
Yes I understand that (now). Thing is, when Gareth Horth talked me through telnet initially (when I was setting up Cron/Webalizer some years back) he made it - very - clear that you have to be really careful with what characters you input.
I could, I guess, have found out using trial and error, but I didn't want to risk putting chevrons in and find it caused some un-ideal outcome, hence the question.
I use telnet a fair bit these days for telnetting in mysql content, so I'm reasonably okay with it, just didn't want to risk stuffing things up somehow
Regards,
Penny.
Message 7 of 7
(619 Views)
