Ticket Raised for intermittent internet
greshoff
I contacted support last night regarding an intermittent internet connection. I did the master socket test as suggested and posted an update to the ticket.
Could this be looked at for me as it is causing a lot of inconvenience?
Many thanks
26 REPLIES 26
greshoff
Re: Ticket Raised for intermittent internet
Disappointed that my ticket has not been updated.
MatthewWheeler
Fixes: 480
Thanks for getting in touch @greshoff
I've tested your line today and I can see that there are some settings on your line that are set too low that may be making your speeds seem slow or your connection intermittent.
I've arranged for the line to be reset to try and fix this. Can you monitor the connection over the next couple of days and let us know how you get on?
 Matthew Wheeler
greshoff
Thanks, Which settings were set  too low?
I'll keep an eye on things over the next few days and let you know. Hopefully resetting the line will improve things
MatthewWheeler
Fixes: 480
Thanks for getting back to us @greshoff
Essentially the Signal to Noise Ratio (or SNR for short) was set too low for your line and may have been trying to make your line faster than it can handle.
Have you noticed any improvement since the reset?
 Matthew Wheeler
greshoff
Thanks Matthew. What are the current settings of the SNR for my line. I have been out a lot but when I have been home the connection seems tro be more stable. Thanks.
Mads
Fixes: 79
Hello @greshoff,
Thanks for getting back to us and letting us know your service is more stable, glad to hear it's sorted.
Do let us know if you need further assistance,
Thanks.
greshoff
What are the current settings of the SNR for my line?
tinytaco
Fixes: 29
General Information
NTE Status:   NTE Power Status: PowerOn Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 6.8 14.0
SNR Margin: 6.5 3.3
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 8285384 24224021
Speed: 1219 20119
 Noor
tinytaco
Fixes: 29
@greshoff I will attach your supplier results onto here for you. Your SNR is currently set at 3dB.
 Noor
greshoff
Many thanks. No further issues to report all seems stable for now.
greshoff
Intermittent disconnections
I had the same problem a few weeks ago which I thought had been resolved by plusnet however it appears to have returned.  The  internet drops randomly. I have done all the usual master socket tests etc. Could someone have a look at my line to see if there is something going on? THanks
greshoff
had the same problem a few weeks ago which I thought had been resolved by plusnet however it appears to have returned.  The  internet drops randomly. I have done all the usual master socket tests etc. Could someone have a look at my line to see if there is something going on? Thanks
Gel
Aspiring Champion
Fixes: 29
Re: Intermittent disconnections
Have you done the "quiet line" test; if voice service noisy, that will impact on ADSL quality.
Just dial "17070".
greshoff
Yes I have done all the usual master socket tests etc including quiet line test
