Throughput issue
- Throughput issue
Throughput issue
17-06-2009 8:33 PM
Hey all..
I seem to have an issue with my line speed:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 4000 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 3500 kbps
Actual IP throughput achieved during the test was - 110 kbps
Downstream Upstream
Rate (Kbps): 4000 448
SNR Margin (dB): 7.3 21.0
Attenuation (dB): 44.0 22.5
Output Power (dBm): 12.3 19.5
Connection Up Time : 46 hour, 35 min, 38 sec
I have not rebooted myself for a long time, so I presume I have been disconnected without knowing.
Any tips?
Edit - Thread title is not spelt so good
jim:blue it is now mod:end
Downstream Upstream
Any tips?
Message 1 of 8
(1,692 Views)
7 REPLIES 7
Re: Throuput issue
17-06-2009 8:53 PM
click modify and change it. you can allways do this if you modify the first post.
Message 2 of 8
(603 Views)
Re: Throuput issue
17-06-2009 9:07 PM
exactly what is your problem?, the BT speed test is only reliable for reporting the connection and profile, not the throughput, it can give useless answers fo this.
Most people decry the speedtest.net test, PN prefere this one http://www.mybroadbandspeed.co.uk/
Your test was using the Manchester server, the place where your signal reaches the internet is in London
Message 3 of 8
(603 Views)
Re: Throuput issue
17-06-2009 9:20 PM
Message 4 of 8
(603 Views)
Re: Throuput issue
17-06-2009 9:37 PM
I have the Thompson router and that seems to refresh itself about once a week, I am on a good connection, so it doesnt affect me, and probably not yours either, I used to have the 2110 dont think that reconnected itself
Message 5 of 8
(603 Views)
Re: Throuput issue
17-06-2009 9:38 PM
Your throughput looks ok for your IP profile, but for your attenuation it should be a little better I would have thought.
You could try tweaking your MTU and RWIN to see if you can squeeze anymore out of it.
Message 6 of 8
(603 Views)
Re: Throughput issue
18-06-2009 9:57 AM
Cheers, I will give that go tonight when I get home, thanks guys.
Message 7 of 8
(603 Views)
18-06-2009 1:16 PM
could allways try at the test socket to see if that gives a sync rate more in line with your line's atten
Message 8 of 8
(603 Views)
