Three Home Signal
- Re: Three Home Signal
Three Home Signal
09-04-2013 7:00 PM
Now happily on PlusNet however I have found that my three home signal box doesn't seem to want to play anymore. I saw an article about the Vodafone equivalent but couldn't find anything about three has anyone else had a problem with one of these?
Message 1 of 7
(1,161 Views)
6 REPLIES 6
09-04-2013 7:06 PM
Is it being blocked by the Plusnet Broadband Firewall ?
Try switching that off, and then restarting your connection.
Message 2 of 7
(611 Views)
09-04-2013 9:12 PM
works fine for me. turn it off (unplug power) for 5 mins and then have a go. if not working then, ring the home signal people at 3 - they can do a reset.
Mike
Mike
Message 3 of 7
(611 Views)
09-04-2013 9:18 PM
Thanks Mike,
Ill give that a try.
I've also turned off the broadband firewall and disconnected and reconnected.
Also mike out of curiosity what router do you use.
Message 4 of 7
(611 Views)
10-04-2013 7:42 AM
the technicolour 582n that plusnet supplied. in fact it works better than my dlink dual band...!
Message 5 of 7
(611 Views)
10-04-2013 7:46 AM
[edit] Deleted - as not relevant
Message 6 of 7
(611 Views)
10-04-2013 8:00 AM
Thanks for your help
All sorted now think it might have been the three box playing up haven't done anything and its all working this morning.
Message 7 of 7
(611 Views)
