Thomson router
- Thomson router
Thomson router
30-11-2010 1:27 AM
Software Release: 8.2.23.0
It goes stupid to day it was reset and tried to log me in as <username removed> were it got that username from I dont know so I had to reset it yet again. Last time it happened they promised a new router as this one is only a few months old but it never came.
Is there anyway to backup the config so if it goes again it wont take an hour netgears and other have it on the menu?
How can you setup up the router to use the ip 10.0.0.2 with dhcp inthe same range? It takes forver as it wont let you remove the 192 range when you change th eip so dhcp wont work I go around in cirlces trying to find a direct route to simple change th eip and dhcp cananyone give a link.
Anyone else have this problem its been 3 times in the last few weeks after every outage it just wont connect again
jim:green a possible other customer username removed mod:end
Re: Thomson router
30-11-2010 9:56 AM
Any chance you can PM me the username that Jim's removed? Better still, could you PM me the serial number of the router please (the one from the sticker on the bottom that starts with CP)? That way I can check the TR69 settings and make sure it's linked to your account properly.
Re: Thomson router
30-11-2010 6:19 PM
Backup and restore settings...
Home > Thomson Gateway > Configuration > Save or Restore Configuration
Re: Thomson router
01-12-2010 1:36 AM
Still trying to find a simple way to change th eip to 10.0.0.2. I found the page once but I end up having to add a dhcp and it won tlet you remove the other then you change th eip but the dhcp is wrong then you can remove the old dhcp its a pain.
Its the slowest router interface I have ever seen and not user friendly as you can never find anything
Re: Thomson router
01-12-2010 2:54 AM
Re: Thomson router
01-12-2010 2:45 PM
On speed test I never get higher than 5318 even though I am connected at the 6655
Re: Thomson router
01-12-2010 3:14 PM
Your line is indeed banded, so you won't sync higher than 6656k This can possib;y be lifted but there are some errors on the line. I know yo've tried a diffferent router but I have to make sure you have tried an alternate filter and are in the test socket.
Jojo
Re: Thomson router
03-12-2010 1:18 AM
Re: Thomson router
03-12-2010 10:38 AM
Some filtered faceplates are just attached over the test socket, although it may be hardwired. Do you know, or have you checked which yours is?
Jojo
Re: Thomson router
04-12-2010 12:45 AM
Re: Thomson router
07-12-2010 9:55 AM
If that's the case then it may be worth trying a normal filter in the test socket.
Jojo
