Thomson TG585 power cable
- Thomson TG585 power cable
09-04-2013 8:32 PM
Hiya,
So today my router lost power and I wondered why so I unplugged it at the socket to find that the top prong on the plug had snapped inside the power socket. I'm not really keen on having a broken plug on in the house and don't really want these constant losses of power either.
So im wondering where I can get a suitable power cable to fit the TG585 or even a replacement clip-in for the prongs(its detachable on my current one)? want to make sure its the correct voltage/size etc thats all.
Any help would be much appreciated.
Cheers
Cheers
Message 1 of 5
(1,546 Views)
4 REPLIES 4
Re: Thomson TG585 power cable
10-04-2013 11:08 AM
The earth pin snapping off shouldn't affect the power, though I appreciate it's not ideal. You should be able to get a replacement though, but it's an odd one - 22v at 545mA. If you can find one with the same size plug you should be fine, hope that helps?
Message 2 of 5
(624 Views)
10-04-2013 11:12 AM
Is it this 1 ? http://wesupply.co.uk/product.php?id_product=7378
Ebay item ses most thompson routers http://www.ebay.co.uk/itm/GENUINE-Power-Supply-Unit-Thomson-Router-Adapter-PSU-22V-TG-585-v7-TG585-/...
Maybe somebody can confirm.
Message 3 of 5
(624 Views)
10-04-2013 11:49 AM
Yes, looks like the same PSU at both of those links - ebay price looks pretty good. Those are definitely the voltage/current output values it needs.
Message 4 of 5
(623 Views)
10-04-2013 4:34 PM
As long as the tip and ring polarity is correct.
Message 5 of 5
(623 Views)
