This is not a very good start.
- This is not a very good start.
Re: This is not a very good start.
19-06-2012 1:16 PM
Quote from: _Adam_Walker_ @crabstix
From what I can see, you seem to be suffering from frequent disconnections which will in turn explain the reduction in line rate.
Is what Adam has said. Given the nature of DLM it is possible that this has had an impact on the connection speeds.
I understand that there is also noise which would need to be eliminated, however the checks advised in the faults tool would also cover this.
19-06-2012 1:20 PM
19-06-2012 1:51 PM
Quote from: crabstix Anotherone, Can't be specific, but earlier today I had to take out the modem because my wife was getting excessive hiss/crackle on the phoneline, when she was talking to someone.
This is a problem I had with my previous ISP, and I had to take out the modem each time. I can't be specific when I reinserted the modem.
The user has confirmed that because of the phone getting excessive hiss/crackle he unplugs the modem. The obvious first question I would have for the user is whether any of the disconnections shown in Reply #28 are NOT because of him disconnecting the modem.
We've also had it confirmed that he just pulls the telephone plug on the modem - it's obvious that the exchange isn't going to like that which will cause the drop in speed.
The first action MUST be to discover and eliminate the cause of the hiss/crackle - swapping the filter must be the first step. If he goes down the raise a fault route it's going to end up with an engineer being called out. If the engineer finds the filter is faulty the user is going to be charged £50!
Quote from: _Adam_Walker_ From what I can see, you seem to be suffering from frequent disconnections which will in turn explain the reduction in line rate.
NSS He's unplugging the router - correct me if I'm wrong but won't unplugging the router from the telephone be seen as a disconnection?
19-06-2012 2:06 PM
19-06-2012 2:13 PM
19-06-2012 2:14 PM
Quote from: Jameseh Jelv - Only if that's been done a number of times (like 5-10 in that time period).
So have you established that?
I find it very suspicious that the graph shows long stable periods and then bursts of disconnections - just like someone unplugging/ reconnecting, rebooting and generally messing about with things when they don't really know what they are doing.
Good job there are users around like Anotherone who spot significant comments in the middle of long topics (like the router being unplugged because it makes the phone noisy)!
Edit: Another thing - correct me if I'm wrong, but if he raised a fault wouldn't one of the first things he'd be asked to do would be to try a different filter?
19-06-2012 2:20 PM
19-06-2012 7:41 PM
Anotherone- I have now disconnected by the method you gave in Reply 10, and after a few minutes I powered down as you advised.
I changed the filter and powered up and reconnected as you advised. My immediate stats are shown below.
I can assure you all that I have only once pulled out the modem since joining Plusnet, and I did not appreciate the possible consequences of doing this.
DSL Connection
Link Information
Uptime: 0 days, 0:13:46
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 12.387
Data Transferred (Sent/Received) [MB/GB]: 391,14 / 1,99
Output Power (Up/Down) [dBm]: 12,4 / 0,0
Line Attenuation (Up/Down) [dB]: 18,7 / 35,0
SN Margin (Up/Down) [dB]: 29,6 / 6,1
Loss of Framing (Local/Remote): 173 / 0
Loss of Signal (Local/Remote): 35 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 5.972 / 46
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 11
HEC Errors (Up/Down): 0 / 50
dick:green Post tidied up.
19-06-2012 8:06 PM
19-06-2012 8:09 PM
I have sent you a PM. Have a quick read and respond if there is anything I can help with
19-06-2012 8:37 PM
PS., Don't apologise, it wasn't your fault at all.
20-06-2012 9:35 AM
I also did a speed check before I disconnected and obtained 2.98MB, and now that I am reconnected it is almost 7MB. This is yoyo time and simply not acceptable.
These are the same symptoms that I was experiencing with my previous ISP, and the reason I moved to Plusnet.
20-06-2012 10:24 AM
Just for clarity, I assume you are currently using a new modem/router and filters suppllied by Plusnet?
20-06-2012 10:49 AM
The second point is about the noise on the line. Recently they switched me to 21CN and on my now old router there was an extreme amount of noise to such an extent that I could hardly hear the other person, it also dropped connection too frequently. Although I never mentioned the noise to PN they knew about the connection drops. They have issued me with one of their own routers and the problems have now disappeared. So maybe as been already suggested if you don't already have one, ask PN for a router, they sometimes defer the cost of it to allow you to test and if you stay with them for a year there would probably be no charge for it. If you leave before the year is out they will then bill you for it. If I am wrong in this then I am sure I will corrected.
Harps1h
20-06-2012 11:11 AM
The best thing to do would be to raise it to us via the wizard at http://faults.plus.net - that'll take you through a few standard checks (please do try them again even if you went through all this with your previous ISP, the results are important and can - and do - change over time) and then it'll raise a ticket through to our faults team who'll run some tests and then get back to you.
We'll make sure to push it on through there, though it'd also be worth trying the suggestions you'll no doubt get in these forums along with raising the fault. There's some extremely knowledgeable people here.
