That time again...
- That time again...
- « Previous
- Next »
Re: That time again...
18-09-2012 12:11 PM
I have put the Technicolor back on and it is working woth RouterStats, D/S noise margin has dropped. Attenuation is 29 on my Belkin and 33 on the Technicolor, that is a big margin, reducing the sync a la kitx from 16000 down to 13000. Also with the Belkin the D/S NM never goes below 5 or above 7, yet the Technicolor is 3.2. Why would 2 routers show such a margin in both Attenuation and Noise margin.
Uptime:0 days, 0:15:45
DSL Type:ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]:1.155 / 10.439
Data Transferred (Sent/Received) [kB/MB]:687,34 / 2,12
Output Power (Up/Down) [dBm]:12,6 / 0,0
Line Attenuation (Up/Down) [dB]:18,1 / 33,0
SN Margin (Up/Down) [dB]:6,2 / 2,9
System Vendor ID (Local/Remote):TMMB / ----
Chipset Vendor ID (Local/Remote):BDCM / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):-
Error Seconds (Local/Remote):17 / 0
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):27 / 41
HEC Errors (Up/Down):41 / 273
Message 76 of 79
(254 Views)
18-09-2012 3:06 PM
After 3 hours..... Had a few phone calls, made a few phone calls, but not when the spikes are.
Uptime:0 days, 3:00:57
Data Transferred (Sent/Received) [MB/MB]:3,01 / 22,05
SN Margin (Up/Down) [dB]:6,1 / 3,1
Error Seconds (Local/Remote):146 / 0
CRC Errors (Up/Down):130 / 244
HEC Errors (Up/Down):172 / 1.203
In router stats it says my line is interleaved, is this a mistake ?
Modem state: up
Up time (Days hh:mm:ss): 0 days, 3:13:53
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Modem state: up
xDSL Annex: Annex A
Message 77 of 79
(254 Views)
18-09-2012 4:31 PM
Quote from: JamesM In router stats it says my line is interleaved, is this a mistake ?
As you have no FEC errors I'd agree that is wrong.
Message 78 of 79
(254 Views)
19-09-2012 3:16 PM
Nearly 2 years of banging on about my speed being lower than it should be syncing at 100000 - 1100000
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 13208 1219
Noise Margin 5 6
Output power(dBm) 0 20
Attenuation(dB) 28 16
I am glad I stuck with it, and it turns out I am not paranoid
Anyway thanks to the BT engineer and all who have imparted their wisdom with me and hopefully the only time I am on this forum from now on is if I can offer any wisdom myself.
Cheers.
Status SHOWTIME
Downstream Upstream
Noise Margin 5 6
Cheers.
Message 79 of 79
(254 Views)
- « Previous
- Next »
