Tell Me Whats Wrong With This....
englishrick
Ok, I noticed a couple of days ago on my ping graph it was going crazy..Its been still forever and now the spikes are out of control...Tried changing gateways yesterday but still the same...
http://www.thinkbroadband.com/ping/share/8931cf8cbf7465ab9eb56ebb21db5b76-23-11-2013.html
16 REPLIES 16
englishrick
Re: Tell Me Whats Wrong With This....
thesawdust
ADSL or Fibre.
If ADSL can we have some stats from the router?  Smiley
englishrick
Fibre...Been nothing on the graph for months until the other day... no noise on line either
Fixes: 1,483
any lodgers or children that have discovered the delights of downloading things?
englishrick
Nope locked down and router not reporting anybody I don't know
Have you tried setting the Plusnet "Broadband Firewall" to "High" ?,  just in case it is something external hammering your connection !.
englishrick
Using Asus n56
dick:quote
I don't think you understand.  Huh
Yes there is a firewall in your Asus N56 which should block unsolicited traffic that has reached your router, from passing through to your home network.
The Plusnet "Broadband Firewall" is a different firewall, it is located on the Plusnet network equipment, and you can configure it to block unwanted traffic being sent to your broadband connection.
If an external source (such as a hacker, or mis-configured DNS record) was persistently trying to connect to your WAN IP address, then that might cause the TBB latency spikes you are seeing if your Asus N56 was rejecting the unwanted traffic, because that spurious traffic is still passing over your broadband connection - and will contribute to your monthly usage figures.
However, I was suggesting setting the Plusnet "Broadband Firewall" to the maximum setting to see the effect of blocking all unsolicited incoming traffic BEFORE it reaches your broadband connection.  This way the unwanted traffic IS NOT using your connections bandwidth, and does not contribute to your monthly broadband usage, and more importantly should not cause latency spikes on your TBB graph.
I hope that made sense ?
englishrick
ok I've set it to high, i'll get back to you tomorrow...
Did you restart your PPP session after you changed the firewall setting ?
englishrick
ppp setting?Huh
jelv
Fixes: 10
Disconnect and reconnect via the router interface.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
The same as doing a gateway hop.
englishrick
Ok its still the same even with the firewall on high
