Technicolor TG582n
- Re: Technicolor TG582n
Technicolor TG582n
28-12-2012 7:27 PM
Just switched on the above router - what is the WPS button for?
Message 1 of 3
(832 Views)
2 REPLIES 2
28-12-2012 7:52 PM
It's there if you want to connect a device to your router without having to input the wireless security key. You just scan for the network on your device and click Connect. Then when prompted press the WPS button on your router and you will be connected.
Message 2 of 3
(380 Views)
28-12-2012 7:58 PM
Thanks Exdee, I'll leave it switched off then (the wps button that is!)...
regards
regards
Message 3 of 3
(380 Views)
