Technicolor TG582n router firmware update required
stuntlyd4
My TG582n router needs update for firmware but my PC is currently unavailable. Could the staff please update it for me remotely
23 REPLIES 23
Oldjim
Resting Legend
Fixes: 63
Re: Technicolor 895gn router firmware update required
Poll removed as it is superfluous
Please check the router type as that isn't one I recognise as being supplied by Plusnet
MatthewWheeler
Fixes: 480
From looking at your account you appear to be using a TG582n?
I'll need to have a word with one of the other guys on how to do this for you but I'll update this thread when I know more.
 Matthew Wheeler
stuntlyd4
Yes it is the Technicolor TG582n sorry misread it, my fault, changed it now
MatthewWheeler
Fixes: 480
Re: Technicolor TG582n router firmware update required
We can get that done however your connection will be down for about 10 minutes while we do it?
Can you let us know which time is best and then we'll get it arranged
 Matthew Wheeler
stuntlyd4
Anytime around lunchtime will be good for me, say noon 22nd Jan?
a4gom
Any chance you could update mine as well please?
TG582n with 8.C.M.0
Anytime during the day is fine.
Many thanks
Chris
Legend
Fixes: 169
I'll pass the request on to Matt so he can arrange it at the same time.
MatthewWheeler
Fixes: 480
Thanks for that guys.
I've sent it onto the relevant people and that should get done today.
 Matthew Wheeler
stuntlyd4
Thankyou
This should help the upload speed be in its normal speed
MatthewWheeler
Fixes: 480
@stuntlyd4
Your upload speed being slow is actually because its capped.
I've placed a order to uncap it which will complete tomorrow and should increase that for you.
 Matthew Wheeler
Topov81
Hi, I'm intrigued by this thread. What does the latest firmware update contain... just vulnerability/stability fixes or new functionality ?
I'm looking for a way of applying time-based access restrictions, ideally on a per-device basis.
Fixes: 158
Hi Topov81,
Welcome to the forums.
I cannot give you chapter and verse on 10.2.2.B features, but the headlines are improved xDSL stability (I'm on 248 days) and (as you've mentioned it) hour by hour access restrictions per device.
I'm sure there are other things too.  Wink
Topov81
Thanks for the reply Townman.  Should I look into updating the firmware myself or would you recommend PlusNet doing it remotely (the earlier posts suggest this is possible) ?
My only concern is knowing exactly which one to use. I currently have 8.4.4.J which according to the page below is the latest for my TG582n router, unless of course I can use the TG582n-PS firmware.
http://products.plus-payh.co.uk/firmware/
ejs
Aspiring Hero
Fixes: 25
Does your 582n have a USB port?
