Technicolor TG582n refusing to show device
- Re: Technicolor TG582n refusing to show device
12-06-2014 10:27 PM
DHCP Pool is set to 192.168.1.100 - 192.168.1.140
My Printer is set to static IP 192.168.1.92 using its Wireless interface.
No issues with using the printer - works perfectly - I can also ping its IP address.
BUT the TG582n refuses to show this device in the WLAN interface - it does not exist anywhere on the TG582n web pages.
Tried cold rebooting the router and power cycling the printer several times - makes no difference.
Am I missing something obvious here?
Message 1 of 3
(892 Views)
2 REPLIES 2
12-06-2014 10:55 PM
The router will only show devices that it knows about and has seen communication from. Unless your printer has tried to access an address outside your LAN (for a firmware update for instance) the router hasn't been involved. You could try telneting into the router and pinging the printer from it?
Or just not worry about it of course
Welcome to the forum BTW!
Message 2 of 3
(468 Views)
12-06-2014 11:59 PM
{admin}=>: ping proto=ip addr=192.168.1.92
Legend : Ping successful(!)
Ping Timeout(.)
Hit ctrl-g to abort...
--- Ping statistics ---
5 packet(s) transmitted, 5 successful, 0% packet loss
rtt min/avg/max = 1 / 2 / 4 ms
Yep that did the trick - thanks for the tip!
I would have thought that sending a print job would have alerted the router to its presence - no ?
Ping Timeout(.)
Message 3 of 3
(468 Views)
