Technicolor TG582n "Interleaved" (ADSL)
- Re: Technicolor TG582n "Interleaved" (ADSL)
24-05-2013 2:32 PM
I have had the interleaving turned off on my ADSL line all, indications ping, sync, no FEC errors etc. indicate it is off.
However my TG582n router insists it is on.
I am using verion 10.2.2.B but also had the problem with 8.4.4.J.
Is this just a reporting error with no consequence?
Is it a fault?
Do all TG582ns do this?
Will it cause problems e.g. conflict with the DLM?
Has anyone any ideas?
TonyP
Is it a fault?
TonyP
Message 1 of 4
(1,496 Views)
3 REPLIES 3
24-05-2013 4:06 PM
Hi Tony
My TG582n does the same.
I believe if FEC errors are shown 0/0, fastpath is on.
Message 2 of 4
(577 Views)
28-05-2013 9:45 AM
Message 3 of 4
(577 Views)
28-05-2013 11:27 AM
OK thanks guys
Every thing seems to work OK,
Just another debit against what could be a really good router if wi-fi was better
TonyP
TonyP
Message 4 of 4
(577 Views)
