Technicolor TG582n diagnostics - ping
- Re: Technicolor TG582n diagnostics - ping
30-08-2017 7:21 PM
Is it possible to ping *from* the router? I am trying to work out why I can't see certain devices on the network, or certain devices cannot see the router.
31-08-2017 9:52 AM
31-08-2017 2:04 PM
The connection is via ethernet.
Is there a later version of the firmware that has a diagnostic page? I've seen some references to that, being a "v2" - not sure whether that refers to the firmware or hardware.
I can start a telnet session with the router, but there's nothing there either.
31-08-2017 2:39 PM
Have you manually configured the IP addresses of the devices or set them to obtain the addresses automatically from DHCP?
If you configured them manually are they all 192.168.1.nnn with a subnet mask of 255.255.255.0
31-08-2017 2:40 PM - edited 31-08-2017 2:41 PM
A couple of questions:
- What type of device are you not seeing?
- Do they have static IP addresses?
- Do you know the IP addresses of the devices on your network
Most likely that the devices currently have addresses on different IP ranges or subnets
EDIT: Cross posted with @jelv
31-08-2017 2:50 PM
I have disabled the DHCP on the Technicolor router through the telnet interface.
All IP addresses are manually entered (192.168.1.0/24).
The device I cannot ping is another router/firewall.
31-08-2017 2:55 PM
What IP address have you given it?
31-08-2017 2:59 PM - edited 31-08-2017 3:00 PM
I'm no network expert, but if they're on the same subnets then fine.
They're no IP conflicts on your network?
Could be be the device does not respond to pings - not all do.
I assume you can't access it at all?
31-08-2017 3:01 PM
I have tried several different addresses: 192.168.1.2…192.168.1.253.
Same results.
31-08-2017 3:05 PM - edited 31-08-2017 3:06 PM
Can you ping the second router if you connect directly to it via ethernet?
I'd suggest you make sure that works before connecting the two routers together.
31-08-2017 3:07 PM
I can get into the router/firewall ok, because it has several LAN ports and two WAN ports. The LAN ports have a different IP range (192.168.25.0/24), and I can ping to and from those to devices in that subnet.
I don't think there is a problem with any of the ports not responding to a ping by design/configuration.
At any rate the firewall/router should be able ping the technicolor, but that doesn't work.
I don't think there is anything wrong with the IP ranges/topology.
But to address the initial question, can I ping from the technicolor router - the answer seems to be 'no'.
Can I get a firmware upgrade to do this?
31-08-2017 3:09 PM
The second router is not rseponding to pings from other devices on its subnet.
31-08-2017 3:14 PM
Why two different subnets? That just makes everything way more complicated than it needs to be for most situations!
31-08-2017 3:17 PM
The techicolour is not going to respond to pings on anything connected via a LAN port that are on a different subnet with a standard configuration. It might work of you change it's subnet mask to 255.255.0.0.
31-08-2017 3:19 PM
Security. I don't want the WIFI to be able to access the LAN.
So it looks like:
Technicolor-WIFI
Firewall/router
LAN
I don't think that is anything particularly novel.
