Technicolor TG582n and Airport Extreme
- Re: Technicolor TG582n and Airport Extreme
24-01-2013 6:18 PM
Just got a new TG582 through the post, I currently have a TG585 which is configured in bridge mode so I can connect my Airport Extreme to it.
Is this possible with the new TG582n?
Message 1 of 6
(2,293 Views)
5 REPLIES 5
25-01-2013 10:15 AM
Hi allosunshine,
If you're using the TG585 in bridge mode then I'd suggest leaving it that way as there will be no difference in using the TG582n to the TG585.
Message 2 of 6
(588 Views)
25-01-2013 5:54 PM
The thing is the TG585 keeps dropping the ethernet connection to the Airport Extreme, hence the reason I want to replace it with the TG582n.
Message 3 of 6
(588 Views)
25-01-2013 6:26 PM
In principle the 582 can be configured for bridge mode in exactly the same way as the 585. Problem is that the 582 doesn't, seem to want to recognise templates that are uploaded to it. You probably need to use the CLI directly to define a bridge configuration.
Message 4 of 6
(588 Views)
25-01-2013 6:43 PM
Any pointers in how to do this?
Message 5 of 6
(588 Views)
29-01-2013 10:08 AM
Hi, it needs to be done via Telnet and the router's CLI I'm afraid, but there's a thread detailing how it can be done on these forums: http://community.plus.net/forum/?topic=105753
Hope that helps.
Hope that helps.
Message 6 of 6
(588 Views)
