Technicolor TG582n - Wake On LAN?
- Technicolor TG582n - Wake On LAN?
Re: Technicolor TG582n - Wake On LAN?
08-11-2013 10:48 PM
i can screen share fine providing the mac mini is on, so i know that part is at least working.
08-11-2013 10:52 PM
If it's the former then you'll need to force the Macbook Pro to send a WOL packet by another means - there will likely be a tool/method to achieve this. Sorry I can't be more specific but I have no experience of Mac's whatsoever.
08-11-2013 10:56 PM
all screen sharing does it attempt to access "MacMini.local.:5900" via the screen sharing tool.
08-11-2013 10:57 PM
08-11-2013 10:58 PM
(what i have to do at the moment is access a shared folder to make it wake up then open screen sharing).
08-11-2013 11:00 PM
08-11-2013 11:01 PM
it's AFP shares, so would be via bonjour.
08-11-2013 11:06 PM
If there's some other magic going on with how Mac's wake each other up then that's likely where the problem lies - it will unlikely be a router/switch issue. Of course, your observations do suggest otherwise given the Sky router success but I am at a loss as to how the Plusnet router could cause an issue.
It seems that you can wake the Mac Mini up with folder access, but just not screen sharing, thus I'd say it is an issue with the screen sharing app.
08-11-2013 11:08 PM
the only change has been the technicolor router.
macbook pro is wifi and mac mini is ethernet.
08-11-2013 11:14 PM
Have you tried connecting the Macbook Pro via the wired LAN and seeing if it all then works?
08-11-2013 11:15 PM
08-11-2013 11:21 PM
08-11-2013 11:22 PM
recommended sniffer for OSX ?
09-11-2013 12:15 AM
09-11-2013 1:02 AM
