Technicolor TG582n - Media Server Settings
- Re: Technicolor TG582n - Media Server Settings
29-01-2013 10:03 PM
My TG582n which arrived last week only does not have the USB port. Is their any documentation on how to configure it as a media server and how do I connect my USB external HDD to it.
Message 1 of 5
(2,824 Views)
4 REPLIES 4
30-01-2013 1:09 PM
Hi rssg,
Welcome to the community forums.
The 582n router supplied on our ADSL connections does not come with a USB port, it's only with our fibre service that the USB version is provided, so unfortunately you would not be able to connect via a USB connection.
Message 2 of 5
(1,041 Views)
30-01-2013 4:50 PM
Thanks for your reply. Is their any documentation on how to configure it as a media server?
Message 3 of 5
(1,041 Views)
30-01-2013 11:07 PM
Quote from: chrispurvey Hi rssg,
Do I have the wrong router? I'm on fibre but mine has no usb!
Message 4 of 5
(1,041 Views)
31-01-2013 11:16 AM
@rssg
It will serve media happily, but you can't get the media to the router because there is no USB port.
@guv
Our fibre router should have the USB port on the side, the only difference in the two router are the USB port.
@guv
Message 5 of 5
(1,041 Views)
