Technicolor TG582n Firmware Update
My Technicolor TG582n Firmware Release is 8.4.4.J and would like it updated to the latest release which I believe is 10.2.5 or something similar.
Can this be done please?
8 REPLIES 8
Re: Technicolor TG582n Firmware Update
Fixes: 117
Any problems with that just give us a shout kheemonahs Smiley
 Adam Walker
Thanks Machare for pointing the way.
Just to confirm with Adam;
I have Windows 7 with the Technicolor TG582n (without USB) Router connected through PlusNet.
I have Flashing Util: TG_UPGRADE.zip  &  Firmware Flash File: PN TG582n R10.2.2.B EH.bin.
Does this seem all correct to you, and is 10.2.2 the latest firmware?
Fixes: 117
Hi, yes that all sounds fine and 10.2.2 is the latest version of our firmware for the TG582n
Let us know how you get on.
 Adam Walker
Fixes: 75
Quote from: kheemonahs
I don't think that flashing utility works on Windows 7. You need the Windows 7 version (Windows 7 Upgrade Tool.zip) from this Community Library article.
David
Thanks for that spraxyt , I probably would have wasted a lot of time and maybe bricked the router trying to use the wrong installer version.
Ever thought of joining Plunet Staff as an adviser Wink
So to re-confirm;
I now have Flashing Util:  Windows 7 Upgrade Tool.zip (TGUPGv7210)  &  Firmware Flash File: PN TG582n R10.2.2.B EH.bin.
Does this seem all correct?
Fixes: 75
Those files seem the correct ones to me. Smiley
David
Thank you, will update over w/e.
